I was wondering wheather the R32 GTS-4 would have the same rear diff as the R32 GTS-t's. reason being that i have a switch to go to 4WD or RWD. Because of the torque split i thought that nissan may have put in 2 diff's that are half the strength of the 1 GTS-t rear diff as the force is distributed and to save on overall car weight. If this is the case then having the switch to RWD could potentially be doing damage to the rear diff as it is taking the full force. does anyone know?
https://www.sau.com.au/forums/topic/100531-how-much-can-the-diff-take/
R32 GTS4 uses the same design/strength R200 diff as R32 GTS-t and GTR (not to mention R33 GTS-t and GTR, R34 etc - there are different ratio's used, of course). There is no problem with strength as long as the diff is in good condition.
under the bonnet, has 4wd or attessa or something on the fuse lid cover to clue you into which one it is. Prolonged use with the fuse out can cause damage to 4wd system(i have heard) if you were to go drifting or something like that. It may be benifitial to raise the car and pull the front drive shaft, about a 5-10min job, 8 bolts in total (from memory)
You don't appear to know how the 4wd works. Rear diff has to be "full strength", so to speak, as the car only engages the front wheels when slip is detected. And I do believe that when the wheels start to spin, there is less load on the diff (less "torque resistance").
Also, in the r32, there is no need to play with driveshafts, as the centre diff has no contact unless activated (unlike r33 and r34).
The fuse under the bonnet is clearly marked.
And I should have my r32 gts4 on the road by next week.
Don't forget to put the fuse back after every run. Enjoy...
Check the FAQ FORUM and click the r32 rwd link. Then rather than pulling the fuse, you can wire up a switch.
Nice one, that was one of my questions answetred too, now could someone please tell me which fuse i need to pull to go rwd, is it the one under the dash, or under the hood? cheers
i know that there is a fuse under the bonnet for the 4WD. its marked on the case : ANTI/4WD/PTC. im not sure if anyone else has hooked up their switch to this but i have ran it through the switch under my dash. i tried to simply pull that switch under bonnet but the car wouldnt start when i did that. ive included pics as to what i have done.and also a picture that is quite possibly the greatest drawing since mona lisa. its literally as simple as my sh1tty diagram and it works perfectly.
P.S. any positive feedback on the drawing is appreciated. hehe.
Edited by GTS4dood
yeah, I've got the switch in my GTS4 as well...
wire coming out of fuse box...
leads to switch under steering wheel.
you can also similarly turn ABS on and off (great for track).
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
