No you should just watch it over time tho the cheap ones dont always last too long, A mate of mine brought a cheap Boost Gauge and his lasted a month. Then it started to creep off, My HKS Boost Gauge on the other hand is still going strong and it came with the car.
So I guess you get what you pay for.
Edited by 7yphon
Greddy makes a nice electronic boost gauge. I currently have one in my car, it reads boost accuratly and responds quickly. Where as my buddy had an autometer gauge that would read 5psi when the car was off :blink:
I have found the Apexi Boost gauge to be great.
But i was considering getting 3 cheap gauges, for temp and pressure, for $220 or the DEFI DIN-gauge set for $600.
I know Defi are accurate and will last for years. But i am thinking; even if the cheap ones are inacurate, you only need to know where they usually sit and be worried if this changes. But now i read that these cheap gauges do alter their readings with time :O.
Is this the case for both mechanical and electric gauges? As i am only getting the electrical type.
I know Defi are accurate and will last for years. But i am thinking; even if the cheap ones are inacurate, you only need to know where they usually sit and be worried if this changes.  But now i read that these cheap gauges do alter their readings with time :).
And the Apexi ones look the best too! :O
yea apexi rocks but cant find one under $275 ...
Nengun: Click Here
OR
RMS Motor Parts Pty. Ltd.
Unit 3 / 662 Whitehorse Road,
Mitcham,
Victoria, 3132,
Australia
Phone: (03) 9872 6669
Fax: (03) 9872 6697
Emails:
General Info : [email protected]
Sales : [email protected]
Trading Hour:
Mon-Fri 10AM-6PM
Sat 11AM-5PM
I would also recommend VDO. If you're not after a fancy dial face and only after functionality, VDO is the way to go. Autospeed did a review and found that the VDO boost gauge was good (Avg error of 2.5%).
To quote Autospeed :
"Indeed, VDO offer good value for money while perhaps lacking the frills and panache of some. Accuracy is up there, and thanks to the German company establishing a manufacturing facility here in Australia, warranty isn't a problem. VDO gauges are available from most outlets and the range of hardware is extensive."
Funnily enough, there is one for sale on Ebay right now :Ebay VDO Gauge
Why spend $240 on an Apexi gauge when a $80 VDO gauge will do the same without having to worry about the accuracy/reliablity of something like Speco. I'm like having Functional stuff in my car, not into bling so I bought a VDO.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
