Hi guys
I've just recently bought an r32 GTR and am absolutely loving the car.
There is only one small problem - every now and then when I am driving around (but predominantely when i'm cruising in the hills) the cabin of the car fills with a strong gas smell. I cant think of what could be causing it, except for possibly a leak in the air-con gas? Has anybody else had this problem or know what it could be that is causing it?
cheers
dave
https://www.sau.com.au/forums/topic/100585-strange-gas-smell-in-car/
In the hills eh? Could it be your clutch slipping ever so slightly? If it is, the smell will come right through the cabin via the gear-shift.
that sounds like it could be it coz every now and then when i put the boot in it slips when i change to second. Is it anything to worry about, or just general wear and tear that tells me it might be time to look for a new clutch?
Well.. definately time to start thinking of a new clutch!
The more it slips, the quicker it'll die completely. Well... to the point where you can't go over 3000rpm or generate any boost at all because it slips too much. I should know, I had that for a month before I changed the clutch.
You'll have to get the flywheel machined at the same time, cause it's prolly toasted, burred, and lipped.
If you take it easy and not slip it too much, it should hold up for quite some time... not so fun when you can't put your boot in though!
Glad to hear I may have helped. Good luck!
A quick and simple test is to try to drive off in 3rd gear. You will soon find out if the clutch is slipping. My question though is what type of smell is it. Have you ever been on a train and get that pugnet smell? if so that its brakes and the clutch smells almost the same. It can't be the the air con because if it was leaking the smell would be long gone.
Randy's right if it is the clutch it will only get worse and not far into the future. Get it looked at soon,,,not every flywheel needs machining because of a slightly slipping clutch,,,mine didn't.
Neil.
cheers for the help guys.
Cant say i've noticed the pungent smell on trains....besides the one coming off half the passengers....
It is quite a strong gas smell like natural gas, say if you've left an element on your stove on for too long with out lightling it.
Got any tips on good clutches? It has a haevy duty puck clutch at the mo, but i think i'll probly put a double plate in, heard they're a bit more durable.
Does your car still have the Charcoal Canister in it?
If it doesnt you way find that on the end of the fuel tank breather line(which runs into the bottom of the charcoal canister) may be open free to air or have some kind of breather on the end of it. Have seen this on a couple of R32's GTR's and GTST's...
Just a thought anyway...
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
