Hi guys
I've just recently bought an r32 GTR and am absolutely loving the car.
There is only one small problem - every now and then when I am driving around (but predominantely when i'm cruising in the hills) the cabin of the car fills with a strong gas smell. I cant think of what could be causing it, except for possibly a leak in the air-con gas? Has anybody else had this problem or know what it could be that is causing it?
cheers
dave
https://www.sau.com.au/forums/topic/100585-strange-gas-smell-in-car/
In the hills eh? Could it be your clutch slipping ever so slightly? If it is, the smell will come right through the cabin via the gear-shift.
that sounds like it could be it coz every now and then when i put the boot in it slips when i change to second. Is it anything to worry about, or just general wear and tear that tells me it might be time to look for a new clutch?
Well.. definately time to start thinking of a new clutch!
The more it slips, the quicker it'll die completely. Well... to the point where you can't go over 3000rpm or generate any boost at all because it slips too much. I should know, I had that for a month before I changed the clutch.
You'll have to get the flywheel machined at the same time, cause it's prolly toasted, burred, and lipped.
If you take it easy and not slip it too much, it should hold up for quite some time... not so fun when you can't put your boot in though!
Glad to hear I may have helped. Good luck!
A quick and simple test is to try to drive off in 3rd gear. You will soon find out if the clutch is slipping. My question though is what type of smell is it. Have you ever been on a train and get that pugnet smell? if so that its brakes and the clutch smells almost the same. It can't be the the air con because if it was leaking the smell would be long gone.
Randy's right if it is the clutch it will only get worse and not far into the future. Get it looked at soon,,,not every flywheel needs machining because of a slightly slipping clutch,,,mine didn't.
Neil.
cheers for the help guys.
Cant say i've noticed the pungent smell on trains....besides the one coming off half the passengers....
It is quite a strong gas smell like natural gas, say if you've left an element on your stove on for too long with out lightling it.
Got any tips on good clutches? It has a haevy duty puck clutch at the mo, but i think i'll probly put a double plate in, heard they're a bit more durable.
Does your car still have the Charcoal Canister in it?
If it doesnt you way find that on the end of the fuel tank breather line(which runs into the bottom of the charcoal canister) may be open free to air or have some kind of breather on the end of it. Have seen this on a couple of R32's GTR's and GTST's...
Just a thought anyway...
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
