Hey guys, attached are some pics of my new POD setup (GF got me the filter for xmas, now that's a women =D )
Just curious to hear/see what others are doing as the car feels a bit more sluggish during the day but better when it's cold, due to heat soak I imagine during the day. I got given some heat shield foam for free when I bought that heat shield so wrapped the intake cooler pipe as well, not idea if that will make any difference or not.
Please forgive my K & N sticker rice, I wanted to put it on somewhere =D Half tried to hide it.
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/
Heh, I thought I might get a few questioms about that. I bought it from a seller on these forums who I think got it from the yahoo auctions. All the instructions are in Jap. It looks great but I'm a bit dubious as to how well it actually shields ^-^
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1835192
Is is actually carbon fibre or is it steel mesh, coz if its steel mest it wont shield at all however i do believe that carbon fibre is ok, correct me if i'm wrong anyone.
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1837053
The material itself appears to be fibreglass with a CF layer on the visible portions.
My shield aside, I was hoping to get some pics and thoughts on how others are doing there setups as I was wanting to run another cold air duct from somewhere =)
Edited by ActionDan
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1837089
LoL :lol: Guys the point of this thread was to get some pics/ideas from others about how they are feeding cold air and protecting from heat. In regards to my shield, I'd hope you could clearly see from the pics that the flat portion of the shield is FAR too wide and would protrude outside the engine bay area if it was on the way you are suggesting. For reference, I did try this, as I originally thought I'd put it on backwards myself, it does not fit the other way round and the air snorkel does not come close to the pre-made hole for it. I've also got a pic from the instructions below that shows how the finished product should look.
Cheers :)
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1838434
Yeah and even though I have this setup, I'd still agree with you. The shield was cheap and I love the way it looks so yeah, had to go for it. I'm keen to get some more cold air flow in that area though, how is everyone else getting there cold air in?
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1838467
From the diagram, it looks like the main purpose is to shield the air coming from the snorkel from hot air in the engine bay.
I remember that someone once said the ideal conditions for a pod filter is to take in air from all directions which you impede by enclosing a pod. This design seems to follow those principles...
..or maybe I'm just talkin nonsense! :)
https://www.sau.com.au/forums/topic/100586-pod-cai-setup/#findComment-1838759
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
