I've been using 25mm bolt on wheel adaptors for about a year now. Had to buy them bcos the wheels I bought did not clear the front calipers :nyaanyaa:
Anyway I've noticed my steering wheel vibrates quite badly on high speeds. Balancing has been done yet this problem still occurs. Was wondering if anyone else uses spacers or adaptors and what are your experiences. Also any comments on whether they're good or bad?
https://www.sau.com.au/forums/topic/100602-using-wheel-spacersadaptors/
generally wheel spacers provide better turn in coz of the wider track stance....im not sure as to whether they could be responsible for ur wheel shacking at high speeds, that could be a totally new problem. Was it vibrating once they were installed or its just recent?
you might need another little spacer that fits inbetween the wheel and the spacer you bought so that the rim fits in there snug, they come in plastic or if you want they can be made up, think alloy machined....go see a mag/tyre place they should have what your looking for.hope that helps
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
