Guy's,
I am about to get my motor back from the Engine Shop. Rb25/30 for my Vl Turbo. I am currently sorcing my fuel system(Standard rail, Malpassi Rising Rate Fuel Reg, 800cc Sard injectors, 044, surgetank and standard Vl turbo pump feeding the surge tank etc).
What do you guy's recommend ECU Wise. I dont have enough for a Motech(Unfortunately). I'm thinking either Haltech E6X or a Microtech....
Also I will need a shop in SE QLD(Good Tuner) to give me a run in tune and then come back for the good stuff once it's run in.
any suggestions would be great.......
cheers
Imtorqing :(
https://www.sau.com.au/forums/topic/100616-need-advice-guys/
From my mates research the new motec should actually be cheaper than the new equivant haltech. So Id look in to it a bit more. He does have a 4cyl, but got a quote of $2200 installed, but not tuned for the motec.
Spend all that money to skimp on the bit that actually runs it. Id rather save for another month or 3.
Just me tho.
We've got a VL turbo, doesn't have the rb25 head though, just all RB30, and it's got a haltech E6K..
But as Dave said, theres no point coming this far and then skimping on the most important part. I'm not sure of the specifics between haltech and microtech, but our haltech works well.
Our VL's mostly (I say mostly.. because I think redcliffe dyno did the original tune) been tuned by Matty Spry, although he hates the car (long running joke), I'd have to say he's the best all round tuner in SEQ. ... maybe even QLD or Australia!! :( (big call!)
He's also tuned our skyrice numerous times and I wouldn't go to anyone else now.
He's straight down the line with no bullshit.
The Haltech is a better unit than the Microtech but the Haltech will cost you around $600 extra. I know of more people who can tune the Microtech but like Erin said....it works well. If I had to choose between the two it would be the Haltech.
At the end of the day, neither will give you any more horsepower than the other so it would be best to surf to their respective websites and see which functions would best suit you. Also talk to some tuners (Matt Spry, The guys at Mercury, Hardcore) and ask them what are the advantages and disadvantages. Be careful as many tuners are not in the habit of giving out free information so you might need to make them think they will be supplying and install/tuning the thing. lol.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
