Hello guys, I have been reading alot of what you all have to say and thought I would fire a couple of questions your way -
1. I have narrowed my Hi stall selection down to either a 3500 or a 4000. What would you run in a 900kg car???
2. I have just changed from a single row SR20 radiator to a R31 twin row with two 13" thermo fans. Would this be enough to keep her cool???
3. Has anyone got a wiring diagram for the Infinity air flow meter???
4. Does anyone think I will be driving a laggy bitch??? I read the RB20 thread and it has me scared. Looking for 320 - 350rwhp then 400 after rebuild.
Specs so far......
Datsun 120y sedan
RB20DET
RB25DET Auto w/shift kit
Garrett GT35R Ball Bearing turbo. Front a/r 0.7 - exhaust a/r 0.63
GTR Injectors
Remapped ECU - Not done yet
Z32 MAF or 90mm Infinity
R31 fuel pump cradle modified to fit std tank with Walbro pump
High mount manifold
38mm Turbonetics wastegate
New Monaro 300mm slotted rotors with twin pot calipers & 13/16 master cyl.
3.6 ratio Mazda Bravo diff with 5-stud conversion to match front
205/50/15 street slicks - 587mm OD
I realise its not a Skyline but any thoughts you may have to help me then that would be cool.
Cheers
Steve
Edited by RB120WHY
https://www.sau.com.au/forums/topic/100642-rb20det-with-gt35r/
Specs so far......
Datsun 120y sedan
RB20DET
GTR Injectors
High mount manifold
3.6 ratio diff
Cheers
Steve
sounds like its gonna be a beast and i think upgrades to brakes and factory seat belts to come before the gt35 is added :(
Sorry ... it has retractable seat belt conversion and i have edited original post to inc brakes. Too many mods to remember all of it. Some more pics....
If it gets up on boost. :blink:
I assume you have gone a .63 turbine?
The .63 should start going well at around 5000rpm maybe a little more. :S
Twin 12" fans without a shroud wouldnt keep mine cool in traffic. Would always boil. :D
Edited by Cubes
there is no point going that large turbo on a stock motor as it go boom very quickly
Thats the thing, i dont read too many sotries about an RB20 with a good whack opf power going boom because the internals just couldnt handle it.
Its often tune, poor fueling, detonation etc. Not doubt a std RB20 has its limits....and their is no way a std RB20 wcould make the most of that sized turbo.
But the fact is the engine would not be stresses with such a sized turbo as the thing would rarely be on boost, with only occassional full blooded runs to redline netting and real boost, power and stress. Well thats how i think of it anyway.
With the auto, and the sized turbo you are running, then my buck fitty says use nitrous to get the thing up and running. Then we will see how long a std 300rwkw RB20 will last... :P
Isnt the auto shift kitted etc? I thought that means in the process it is toughened up?
I agree about the response, but the only thing along with gas that i would be looking at is changing the diff ratio to a rotary like 4.11 etc Whilst the thing wont be responsive, you have to consider the light weight of the 120Y means it wont need huge amounts of torque to push it around, and the auto with a higher stall means the turbo wont stop spooling on shifts....
I stil lsay you will need a different diff ratio :P
Anyone want a cheap GT35R???? I think I will do the whole trial and error theory.
Just drive it and see how it reacts and change it to suit my needs later. The turbo is rated at 450hp??? i think so. I got the 0.63rear housing and even though its BB it will still be laggy???
Stay tuned for a cheap turbo... Never boosted. :lol: :lol:
a GT35R with the .63 rear is good for 620ish HP.
I reckon you should take a lesson from Nike - Just do it then see what needs to be changed later on. The worst thing that can happen is that it doesnt work or you blow up a $400 motor trying.
Give it a shot and let us know what the results are like :O
Cheers,
Matt
Sounds like a competitor with this cars setup.
I am doing the same thing with a drag racer.
RB20DE+T, around 900 Kg, 5000RPM staller with an all out trans braked auto, mini spooled 9" with gears in the 4.11:1 to 4.8:1 range, 30"X13.5"X15" rubber.
Thats the car in my avatar.
You can check it out at our site.
http://www.turboclub.com/Australia/Members/AU0000005/
The pics are 6 months old now so I should update.
I'm using an Autronic SMC management system to run the engine and other gadgets.
Here is some pics of the turbocharger, I hope they still come up.
http://www.skylinesaustralia.com/photopost...00/ppuser/19114
Good luck with your car, let us in on the progress.
Cheers
Turbine
gt35r may be a touch laggy, i would go with a gt30r as it works well on my car......
also the motor should take it but a poor tune on mine did her in, oh well live and learn i suppose.
Do you have any specs on the tune itself that messed it up?
The RB20DET's are tough motors.
I had thermo'f fitted as I was going to run FMIC piping through the engine bay. The silly mechanic fitted 2 x 12" davis fans directly on to the core. They didn't flow enough air over enough of the core, resulting in overheating in summer (30+degree days).
It just happened that my dash coolant temp sensor buggered up so normal operating temp (half) was reading as just above C to 1/4.
In traffic temps would increase to around half to 3/4.
I was wondering why coolant was blowing out of the overflow and the car was pinging easily.
I drove it like this for a whole summer, I had the rad cleaned etc made no difference. I was told it was a head gasket.
I replaced the temp sensor at the end of summer and discovered that when the temp guage was hitting 1/2 it was actually sitting on the H and maxing out the guage, that being around 110+ degree's. As soon as I would hit the a/c and any kind of traffic it would creep over 1/2 so god knows what temp the coolant was. It was enough to boil it with a 50/50 mix so no doubt it was up around 124+ degree's, it also blew a coolant hose.
I then drove it for another 60,000km's or so still with perfect compression and no ill sideaffects. Damn tough motors the RB20DET's, the overheating saga and not blowing up on me definitely earned my respect for the buggers. :P
The motor was still fine the day I pulled it out to slot in the rb30det.
Edited by Cubes
what xmember did you use to fit the rb into the 120?
ive wanted to do this conversion for quite a while
Braced and modified the standard one with 5mm plate. I would not try the conversion again. There was a cockup with the original measurements and we found that it would fit nicely..... Until I purchased the engine and sat it in the engine bay and thought, fark what a waste of money. We decided to fit it anyway and have it as a drag car. After talking to some engineers/mod platers we were confident enough that we can keep it street legal, except for a screamer pipe. :P So far so good.
    • GTSBoy on your suggestion on another thread I had a look at those injectors and ended up getting them because of the quality.  Got the expensive ones.
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
