  frankxy said:
as a matter of fact, R32s have become a new generation of posing cars coz somehow everyone thinks a R32 goes faster than a R33. and thats y they are so popular nowadays.
Skylines in general can serve as posing cars. I mean, there are people who don't want performance at all, there are a few non turbo models with very nice bodykits, rims, interiors etc.
For some reason, Skylines at the moment have more "street cred" than any other car....or as some people describe it, the wank factor. lol
Meh.
What can you do.
  • Replies 71
Posted Images
I bought my car for various reasons, it isn't a ford or holden, it has potential for much higher power with minor mods, it looks good (to me) and is a well built, reliable car. The same can be said about other imports but I'm extreemly happy with mine.
  Mashrock said:
so when you think about a nice 32 gtr is around about 25-27. if you want something that is atleast decnet.
33's are pretty cheep in this respect.
Hmm 22-25k you could get something decent i reckon.
More than 26k onwards i'd expect a pretty immaculate 32 in all aspects.
Depends on your luck.
Meh.
What can you do.
yeah they do have a massive "street cred" only because in 2f2f the skyline won and not the supra!!! also alot of people mistake a gts-t for a gtr... i think gtr is what makes the street cred. and word skyline gives the rest of the street cred to the gts-ts
but all and all... every single car theres alot out there!.. well most.. for example i see alot of stock commadores... and i dont give a second look coz it aint a poser or a "racer" etc etc... same with skylines... see alot of stock r33's and i dont give a second look.... but if its got mods... you look coz u know the person likes to mod... so whats under the hood???
or whats up in the hood...
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again馃様 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
