60ft = 1.804 sec
ET = 13.033 sec
MPH = 104.4
Clutch was struggling... Launched at 3500rpm, anything more and clutch would slip..
Want to upgrade clutch so that I can get it into 12's..
Cheers
Rob.
ps. Have to post video soon..
https://www.sau.com.au/forums/topic/100648-took-the-s4-to-wsid/
Thanks,
Not much, just chip and cat back exhaust..
Is it a current model RS6?
Can I ask why it is off the road? (any mods?)
Benm,
You used to own an gts-t right?? I think I remember you at the dyno day we went to when I had a silver skyline.
Cheers
Rob
Dude, I'm not too sure your air intakes are big enough... :) Lookout, roadkill!!!
IIRC, the S4 has twin intercoolers, right? One on each side so each turbo's charge is cooled seperately? The car looks awesome with the air intakes opened up like that! What did you do with the spotties, though?
My old man has a 1.8T in the slightly darker silver (Agate Grey, I think it's called) - as much as I tried he wouldn't sign for the Quattro/6spd, but it's a nice car none-the-less, if a little stiffly-sprung.
Good luck with the future mods and quicker times - a fresh clutch should work wonders.
GTR32X,
Thanks mate
NissanFreak,
mmm 331kw's of goodness :P
benm,
Changed, prefer 4wd?? Any mods planned??
Moanie,
Ahh thought that was you, you walked past me and I thoguth you looked familiar..
I was introduced to you like 3 yrs ago. (silver gts-t with turbo upgrade right??)
Did you have a go?? what did u get?
Cheers
Rob
Moanie,
Cheers
Rob
hahaha... yeah thats me!!! are you serious??? where? what were you driving then?!
nah... didn't have a go! car needs a few things fixed! will be out there in the next few weeks!! when you heading back?!
haha
Can't remember now..
But I was driving the same car as u :)
I'm thinking of going to Oran/Wakefield next, want to test my semi-slicks out.. I don't go to WSID often, infact it's the 2nd time I have been there.
Talk soon
Rob
Ps. Let me know how u go :(
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
