I own an R33 GTS-t with just an exhaust system and pod filter, and noticed that in the heat we've been having lately the car can feel a little laggy. I'm only running stock boost but i'm hesitant to rev the car much beyond 4000RPM on the really hot days, just seems cruel.
I've been considering a Hybrid Intercooler kit, but not having too much tenchnical knowledge i don't know what to look for. I found this one on eBay and i'm wondering if it would do the job?
Hybrid Intercooler
I plan to run a little more boost futher down the track but not straight away. I'm mainly more concerned about the welfare of my engine and components.
Also, for those people who have installed intercoolers, is there something i can say to the insurance company that doesn't scream 'performance upgrade' when i tell them what i want to do? Cause i figure if they feel it'll increase performance it will also increase my premium. I realise that without raising the amount of boost it won't make a huge impact on the performance, if at all.
Thanks in advance!
I am also curious to know what type of cooler or if there are any straight bolt on kits available for my r32 GTST...
with the insurance you can tell them its only for the safty of you turbo because we have hotter weather then Japan we ned to cool the turbo more efficently ( dont quote me on that i just thought of it then)
That's not really what intercoolers do. They cool the charge air into the engine... your stock one should be fine, even in the heat.
If you're worried about your engine on hot days get an oil cooler. A stock skyline won't have problems on hot days it's just not running as well as it would be in cooler weather because cars won't boost as much on hot days.
I won't take my car out on 30-40degree days at all.
Hybrid Intercooler
Thanks in advance!
If you don't already have it, start with a heat shield and a cold air feed for the POD. Unshielded PODs are a big power killer, especialy on hot days.
:O cheers :)
We found another black s2 manual coupe with stockies, eh Dezz? ;o)
Same thing here, I don't go over 3-4K on a really hot day. With the A/C on and the clutch-fan locked on, the car is very sluggish... but the clutch fan is doing its job of cooling the radiator, so I drive softly and count the hours down till the sun sets.
With insurance, its a big ad saying 'I have a big shiny intercooler, therefore my car is turboed' I think thats more so what they are worried about, and the fact that you want the cooler for a reason, and it might be for the safty of your car, but if your not on boost, you dont need it, and your not going fast. The cooler is telling them otherwise. Insurance companys arent stupid, just the people on the phones can be.
And I dont mean to come across as rude, but they are cars... not babys. They can take a bit of punishment.
p1r48r, if you have concerns about the big shinny intercooler thing at all you could go for a ARC SMIC considering you are going to keep the boost low :P Awesome stealth mod !
StOjA, one of the best kit's for a 32 GTST ( IMO ) is the TRUST V-SPL since it bolt's up perfectly, there's no need to cut any 6" holes in your body work, the return pipe from the cooler to the engine runs mostly in the cool air flow and not in the engine bay, right in the path of hot air from the radiator and there's minimal cutting of the bumper / reo required. It does depend on you $ situation though :P
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
