Hey all :)
Got some gear for sale (sorry about pic quality - only have camera phone). All items are in Melbourne. My contact details are at the bottom of the post:
Item: K&N pod filter
Item Condition: Very good condition - only used for about 5000kms. slight mark on one edge of the rubber neck
Reason for Selling: Just discovered this lying around - used on my previous car. Have no use for it now...
Extra info: 4" base diameter (2.5" neck diameter)
Price and Payment Conditions: $50
Item: R33 S1 front bar - genuine plastic
Item Condition: Brand new...never painted or fitted
Reason for Selling: I'm using an aftermarket front bar
Price and Payment Conditions: $100 (pickup)
Item: R33 stock F+R sway bars
Item Condition: Good condition
Reason for Selling: Have upgraded suspension
Price and Payment Conditions: $50 for both
Item: R33 stock front and dump pipes
Item Condition: Good condition - probably needs a clean with a wire brush
Reason for Selling: Have upgraded dump pipe
Item: HKS pod filter - with afm adaptor
Reason for Selling: Have changed to a different pod filter
Price and Payment Conditions: $50 for both *THIS IS SOLD*
Item: R33 stock shifter and leather gear knob
Reason for Selling: Have short shift kit
Item: Bosch 040 fuel pump
Item Condition: Fuel pump is brand new - never fitted. Box is intact, plastic has been opened.
Reason for Selling: Not required at this stage.
Price and Payment Conditions: $180 *THIS IS SOLD*
Item: R33 GTR copy grille - fibreglass
Item Condition: Excellent condition - never fitted
Reason for Selling: Intended to fit this but have decided not to
Extra info: Painted black, mesh has already been attached
Price and Payment Conditions: $70 - *THIS IS SOLD*
Call Ché on 0421 062 501.
email me: [email protected]
or PM me
Edited by kasanoff
  • 1 month later...
Is it a genuine bosch fuel pump? Will you take $150?
Is it a genuine bosch fuel pump? Will you take $150? Where bouts in Melb are you located
Pump is genuine - model number printed on box and stamped on pump is "0 580 254 040"
GTS-T_Sedan: Pm sent...
  • 3 weeks later...
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
