im about to install some new speakers into the car and just wondering if the stock wiring for the stock speakers are alright to use for the new speakers.
I am really concerned about this because on my last car i install ed some new speakers and it worked alrite but i could smell some strange burning smell whenever i pumped up the volume...
Also is it better to just stick to 6" speakers in the rear since im gonna have a sub running or should i go with 6x9"s????
cheers
https://www.sau.com.au/forums/topic/10082-stock-speaker-wires/
I'm with the Pred.
I personally think 6x9's are a waste of time. Decent 6's and a sub/amp will be heaps better.
Your stock wiring should do fine. I'm running good speakers from an amp using stock wiring (for part of the front at least - i reckon the effort of running new wires to the front doors is not worth it) and i have no complaints.
The smell may be the actual speakers themselves, not necessarily (sorry if i can't spel :D ) the wiring. Most speakers generally don't draw current to the point that it will melt the wires (most car wiring can handle at leat 10amp).
I could be wrong, but all the same I reckon you'll be fine.
i decided to use my stock wiring however i decided to put in 6.9's for my own reasons which i cant be bothered explaining, however it was a mighty task so if ur not prepared to slug it out in the back seat for 1 full day hacking away sweating like a byuetch and cuting urself every way possible just go with the 6 inches, that way u can use the stock speaker grills and conceal ur stereo from woodbee whores!
  • 6 months later...
i think the decision to use stock wires really comes down to how good you want the overall system to sound - if your putting in high end speakers then you will be really shooting yourself in the foot if you dont upgrade the wires. Whats that law - the system is only as good as its worst part...
I'd be carefull trying to run too much current down your stock wires. The thinner the wire, the higher the resistance, the more heat that would be output. It doesn't take much to start the insulation smouldering. It also wouldn't be doing the rest of your system justice.
Quality wire doesn't cost the earth and is fairly easy to install through a skyline.
The 6" + sub combo should do you well.
i'd leave my stock speakers and spend more money on the sub/amp, and amplifier the splits really nicely.
skylines r small cars inside the back seat so theres not much point for rear fill when u've got a sub and nice splits.
thats my opinion anyway, it'd sound awesome with 6's aswell im sure (:
u can use stock speaker wires, the smell u were smelling was probably the seal from the speakers on the sides etc. i doubt it was from the wires.
dont go 6x9's if u've got a sub, theres no point... good 6's would give good enough bass too, whatever bass it doesnt output, comes from ur sub, and u'd rather those hard lower frequencies coming from ur sub, 6x9's would take them away.
It's always required that the speaker cable be upgraded when higher current (ie from an amplifier) flow is required.
As for 6x9's, you sit at the front and your ears face forward, so why (unless you're running DTS etc) bother with any speaker in the back? Besides, the stock ones do their job of fill good enough. :(
fhrx,
yeah hiss changes with the revs. i just bought this car and it came with a sony xplod md head unit 50x4W running the back speakers direct from head unit (130W kenwoods 2 way) with an amp of some sort (avantgarde comp series? - its silver and 4 channel anyway) running the fronts and a xplod sub on a bridged channel. the hissing seems to come from the fronts. i used to have this problem in my old prelude, but i fixed it when i seperated the power cable to the RCA's. In the skyline thou, the power cord is right to the battery in the boot as you know so i cant seperate them any further.
Quality brands usually have their branding all over their products.
no name stuff i think thou.
There lies your problem. :)
High end installers are always crapping on about using high end cable. There is a good reason for this.
Like you don't use quarter inch plastic fuel lines on a nitro funny-car, nor should you use cheap cables on your stereo or this sort of thing happens.
Now bare in mind I am only going on what you have told me. If you want a more definate answer to what is causing it, I can come and meet you somewhere and diagnose the system no problems. :)
    • Some of the filler.   Also if I look under the top flap of metal it starts looking good quite close to the edge. I get the feeling it doesn't go much further.
    • So, I finally started digging at the bit of my roof that was cracking and bulging a bit. Well, it was just thick filler that was covering some pretty bad rust. I didn't find the edges, I was too bummed to keep going.  There are a few holes as you can see. There was just so much filler but looks like no attempt under the filler to prime or use rust converter, just slapped filler on exposed rust.  Anyway, I'm going to take the windshield out and find the edges. I'd love to fix this myself as I'm pretty sure it'll be expensive to get done properly. I was thinking I could just get a cut piece from another E39 and just weld it in place as it would be the right size and shape.  Thoughts?
    • This is the territory of the "Stage 1/2/3 Golf GTI/R" or otherwise off the shelf tune with (relative to before) minor mods. It's easier now. Downpipe and Tune and boom, big increases. Stage 1 OEM+ is where it's at. This is where the niche evolved into and it's really easy to see why. It's rare to even NEED to consider changing turbos or going to aftermarket ECU's or building bottom ends for more power. Stage 1-2-3 will get you a LONG WAY. Civic Type R turbo GR Yaris/Corolla Anything with B58 (MKV Supra/x40i) Anything BMW in General Anything Audi in General Any turbo AMG RenaultSport Turbo offerings Korean Elantra N/I30N Ecoboost Mustangs Focus RS? List goes on. I would argue in the future it won't even need to go on... M3P is pretty rapid out of the box...
    • There is a way, but it's not with the same cars. You need to find the same vintage of car, that we had. Realistically, that was an affordable car with aftermarket parts around. So what people need to find is a car that had a decent base in its day, and can be modified. They're looking for a car year make of 2010 to 2015 really... Aus could have done it if Holden didn't fold as V8 commodores were cheap, and if Ford didn't get expensive thanks to COVID, then you could cheaply play with FG Barras. Realistically, those are just a bit heavier, four door skylines. I'm sure the US and UK have similar cars they could find.
    • Haha I do that.. thats when it chirps..The bit point for me is almost non-existent. Otherwise I stall it. But yes, in terms of performance, the clutch is solid af.
