Skyline R32 1990 Rb20det
Its a 1990 Black R32 Skyline and is in immaculate condition. NEVER BOOSTED runnign safe stock 7psi. No problems, and everything was serviced before it came to Australia, including major service, upper control arm bushes. Regency inspectors even said that it is one of the best quality r32 they've inspected! huh.gif Have Inspection papers too!! Was imported under the 15 year old law around july This year. CAr has been on the road for at most 5 months.
CAR
- Auto with 114xxx (serviced at 112xxx)
- ALARM and IMMOBILISER
- 3.5" cat-back Apexi Megaphone DUnk. 5"outlet, 7" barrel (off GTR)
- CatCO 3 " hiflow cat
- Stock rims with good tread
- new battery
- Serviced every 4,000km (oil+oil filter)
- HKS Turbo Timer connected to Alarm
-ALL STOCK PARTS WILL BE INSTALLED
PRICE: $8500 REASONABLE OFFERS, No BS
REASON FOR SALE: buying a drift car from japan. Cost too much to convert this 1! And no, it hasnt been thrashed, cause its more my mum's grocery shopping car :D biggrin.gif
CONTACT: 0434345424 or PM me
PICS UPSOON AS IT IS BEING STRIPPED OF MODS TO STOCK
Can you send any pics to [email protected]
thanks
CAR
- new battery
REASON FOR SALE: buying a drift car from japan. Cost too much to convert this 1! And no, it hasnt been thrashed, cause its more my mum's grocery shopping car  :rofl: biggrin.gif
  • 3 months later...
  • 4 weeks later...
 Share
    • That's the most absurd thing I've ever heard. I would go cut bellhousing over that monstrosity of a flywheel all day, every day. It puts a lot more mass further from the last main bearing. I've had nothing but problems with Collins in the past and refuse to ever buy their products again. I would not trust anything they tell you. He's playing his salesman card.  I'm currently at 640whp on a mustang dyno (~770bhp) with the intentions of running E85 and a lot more power this upcoming spring. Cheers,
    • Nah, it's not the reduced knock margin. It is a direct mechanical effect of having to initiate the combustion earlier, while the piston is still rising, which starts to exert combustion pressure on the rising piston earlier, making the rest of the engine work harder to finish driving the piston up to TDC where the combustion pressure stops being a negative and starts being a positive. Your modern engine that only needs ~10° to make MBT doesn't waste the other 10 or so degrees of crank rotation. That's almost all of it. The difference in knock margin might go either way. Remember that modern engines to which you are currently comparing the long tractor engine (the RB) are now running super high compression, direct injection, tricky cam control and maybe even cylinder pressure sensors. You're not comparing apples with other fruit. It's apples and sea weed, or some other evolutionarily primitive vegetation. And remember, squish only really comes into play at the very end of the stroke. It certainly does good things, but it is not the biggest contributor to what's going on. It is quite possibly much less important in 4 valve head than 2 valvers also, because there is so much less squish available to a 4 valve anyway.
    • Food for thought, a longer stroke motor would need less ignition timing vs. a shorter stroke motor requiring more ignition timing.
    • Thanks Duncan, HART is only 10 mins from me (I did my bike license there), it'd be awesome if it ran these types of things.  Sutton Road does look good and they take fewer cars than SMSP which is good.  Surely you have enough land to lay a few million tonnes of concrete and some sprinklers D?
    • I thought an engine that needs more ignition timing to make power is going to result in less power due to reduced knock margin? More time for the combustion to propagate -> more time for it to heat up the rest of the mix to detonation.
