Hi all.. was wondering what everyone thought bout puting a turbo in a clean mr30 Sadan that i recently pick up. it has a rebuilt L24E, 5speed and IRS. To turbo i was thinking of finding a L20ET menifold and ecu do they bolt straight onto the L24E if so do i still use the L24e injectores and fuel rail. Also how hard is it to upgrade my motor to a Nissan RB30ET my mate is selling a worked one out of a VL Calais.. what would be involved in fitting it in the skyline. Also anyone with L20et parts they wanna get rid of give me a bell on [email protected]
Thanks for the help
Luke
https://www.sau.com.au/forums/topic/100836-mr30/
Luke,
I have one of the hatchback versions. I also investigated just grabbing the turbo gear of an L20ET and whacking it on the side of the L24. However, it was suggested it would probably ping its brains out since the combustion chambers weren't designed to operate in a boost situation.
But then, if you installed aftermarket ECU, it would obviously possible to tune it to suit.
I happen to have available a L20ET, that I ran in a 240Z for a while. It has since been modified with a RB20DET BB-centre turbo, as well as still having the gear to hook up a Wolf 3D ECU. Also has been modified to use a small intercooler.
As for the VL motor, I am lead to believe that basically all that needs to be done to install any RB-series engine into the R30 is to get hold of the R31 X-member, then the engine will drop straight in. Then of course, you need the RB gearbox, and the RB drive shaft.
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1840646
Luke,
hi man thanks heaps for the info y would it ping under boost i dont understand??? Also How many km's on your l20et might be instrusted if you where selling it. how much would u ask? $$$ B)
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1841185
I think it's because of the design / shape of the combustion chambers. Just what I was told, but the last thing I need is an engine that pings.
Probably 100k on it, but the L-series engines I have found to be almost bulletproof, not like the RB-series.
I replied to you "Wanted to Buy" with a price. That would include an intercooler, and the RB-series dump pipe. The engine is set up to run off a Wolf 3D - that is available also, say $300 for ECU + loom.
I'm in Melbourne.
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1841364
Let me ask some people about freighting it up there. I can probably do that price as a "delivered to your door" price, depending on the freight cost.
It should simply drop straight in and bolt up to your gearbox (as willl just about any L-series engine).
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1842236
I asked around and $350 for a compleat L20et with that many km's seems to be the going price... a mate scored one for 200 bucks with some barganin from the wreakers that had just been taken out of a dr30 or hr30 or something he was saying
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1842325
can i ask how much is your mate looking to sell the rb30et for?
the L24et should be good to run stock boost 6-8psi without problems, some tuning time will help, are you getting the wolf ecu? intercooler is a must to run higher boost plus nothing but BP ultimate too. engine will live a bit longer.
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1843376
i was either going to get a l20et motor wolf 3d and has been setup for a intercooler or just get my hands on a l20et menifold turbo and ecu would i use the ecu from the l20et or l24e
would my l24e with that l20et turbo setup running 8psi be reliable and last
also what power increses can i expect
my mate had a vl calais that he wrote off and is selling the motor and box for round $500 i think i will make sure and post a msg
https://www.sau.com.au/forums/topic/100836-mr30/#findComment-1843490
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
