Im up for it, I was just getting into the calder drift practise days and now I cant, I would really like to see it continued because Its a form of motorsport that I enjoy competing in.
I know a quite a few other people (who are not on the forums/internet) that have been attending calder drift days for the past year regularly and who would do almost anything to get back into drifting on it, I was having a chat to one of my close mates whos really into It and he was very very dissapointed to hear that it was to be called off, not only that there are guys who have bought/built drift cars solely to be used on the track, Id imagine theyd be pretty upset.
Anyway, thats my 2c, good luck to anyone that can work something out, if I can be of help, please message me
Regards
Kim
Great to hear. I have had a number of emails about this and I would like to see more people b4 we organise to have our first meeting. Once you have sent your emails in you will be on the contact list.
You could use SAU as an already set up club with a committee and everything already worked out, and have a sub-club sort of thing to get licenses etc. Setting up a club for Cams Affilition isn't easy.....
Took the boys here a lot of work and there's a lot of stuff that needs to be sorted out.
Guys it seams like the fulllock website is down atm. If you would like my mates and I have been working on a tech site that has a forum. www.importworks.net go there register and that way we can get all the drifters in 1 spot until the club is sorted out
id be up for it, you might be able to try gippsland park hill climb track i know they dont have all that many events any more so they might be keen. people who want to legel srift should drive the 2 hours
Hey guys every vic drifter interested in this club needs to go to importworks.net and reg so that we can start things moving
Wow - I've never seen a forum so clean...
just a question though - whats wrong with here?
Though I hope you do get it up and running. I might even see you there....
Hey nothing is wrong with here. Its just that we had this post on NS/fulllock & here. So insted of running 3 different topics its easier to run 1 so that all of the drifters that are interested can meet there. Also the club isnt a part of SAU or NS so its a little unfair to use their forums for club business.
Ok we now have over 50 people interested in the club we are currently looking for a hall do have a meeting. We will keep you posted as to the date & time that the meeting will be on. Please remember that www.importworks.net is our first line of contact. So please reg.
It looks like we will be forming our own victorian club & not becoming an extention of another club this is due to a number of problems due to money & time. This means that we need a club name so can people please go to the web site and post up a club name so that we can take a vote on all of the different names at the first meeting.
Hey guys we have got a club site up now with everything needed on it. Please go to www.vicdrift.com and register. This site is where the info for the first meeting will be put up next week. So please reg & keep checking for updates
www.vicdrift.com
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
