Hey ppls.
I got EPA’d again.
Performance Exhaust in Ringwood recommended replacing my Cannon at the back with a Magnaflow box.
Reckons with no other mufflers, this will make the car legal.
Anyone had any experience with Magnaflow?
Sound good?
https://www.sau.com.au/forums/topic/100843-magnaflow-mufflers/
  • Replies 65
hay bass they are not bad we (my dad and me got one made up for just for epa stuff) they are great and sound ok but just get a flang puton behind the cannon and get a stock muffler and bolt it on and then get it tested and when you get home change it over again.
I'll be putting in a flange so that when racing I can put the old muffler on just for aural pleasure.
I'll leave the Magnaflow on all the time, cos it's too loud in the car at the moment.
I HAD a stock exhaust and I lent it to HasLo on these forums.
It has since been fitted to his car for complience and then lent to one of his friends workshops who backed over it with a forklift, so I have no exhaust.
I want to reduce the noise of my car anyway, so the new muffler is the go.
...driving around in James' brothers WRX which has a Magnaflow cannon, it is still damn noisy for a stock car with stock exhaust apart from the muffler. Dotn know what model muffler it was...but i supose if you get one of their quiet exhausts rather then a 'performance' exhaust ????
Oh, and it's got a slightly offset muffler (Fujitsubo) in the middle
It's got a muffler in the middle AND one at the rear and it's still too loud. Damn they must not be much of a muffler.
What we do is fit a bolt in restrictor in the rear muffler, then it is a simple matter of undoing 4 screws and removing the restrictor. The restrictor is a reverse cone shape and makes the exhaust bounce outwards into the silencing material, rather than go straight through. With your access you should be able to make one up out of stainless steel pretty easily.
You trim the size of the hole in the restrictor until you get the desired noise level. Start of quite and gradually trim until it is at the limit. It does knock the top off the performance, but it is quick and easy to remove.
:P cheers :P
damn , i just fit a trust power extreme II about 3 weeks ago
theres a r33 power getter but no 34 so I guess its that . did you have to modify anything to get it to fit ? i had to mod my peII for the 4 door and that was a r34 exhaust anyway
strange that its loud , fuji are one of the quieter exhaust manufacturers around and my s15 power getter had no problems passing the pits .
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
