  • Replies 65
i have a 3inch front pipe, 4inch magic cat, and hks super megaphone catback, it has a large straight through 3inch muffler and is one of the quietest i have ever heard on a skyline.
edit: it also has a straight throughhot-dog style thing in the middle of it, but no real centre muffler.
Edited by siksII
ive got a 3" front system, with a split 2 x 2.5" after the "race cat pipe" to the rear with 2 x 3" mufflers.
Its one of the quietest exhausts i know, and doesnt drone. Its also mild steel.
if you want a quiet exhaust, make it out of mild steel. You will sell your car before the exhaust rusts off...
I followed the ford exhausts...why? Because they have 4lts, and a gt35r to shut up. And they did it with a split system...
Cats and mid mufflers dont mean jack to quieten an exhaust...
Edited by Bl4cK32
(R32 GTR, 330awkw)
I have:
HKS Exhaust Manifold
HKS Front/Dumps
DoLuck Cat + Cat-back with a 6" Canon
I got it tested last week and it was 120db at 3,500rpm. Not only was it extremely loud at idle (have Tomei Poncams too) but the drone was ripping my ears apart (especially when i'd done 4x 250km highway drives in the first 2wks).
I got a local exhaust workshop to replace the rear DoLuck canon (straight through pipe with baffling around the outside of the pipe) with 1 of their own. Their was a flange (4 bolt grr) right infront of the rear canon so it was just a matter of adapting the custom muffler to a 4 bolt flange and swapping it over (also had the entire cat-back raised 3-4cm). The result was 98db at 3,500rpm and absolutely no drone at all which is still way over the limit but i'm not sure whatelse could be done without making the car undrivable.
The annoying thing about this custom rear muffler was that its taken away the awesome "worked RB26" sound and also my power/boost is way down. I changed the rear custom muffler back to the DoLuck canon yesterday in the garage, pain in the ass 20min job. No point going to the drags with half your power stuck in the rear muffler.
I'd really love to get a whole new cat-back that is 1) 90db or less and 2) capable of flowing 330awkw but unfortunately I don't think it is possible. Having a 4 bolt flange on the entire system makes it very difficult to just swap over individual parts with other brands/models to see the difference as basically every but needs to be custom welded.
Edited by benm
Hey ppls.
I got EPA’d again.
You suck at teh not attracting attention to yourself.
That is all.
Maybe you should cut down on those bootycalls to adz's place in knox..
Bass,
Talk to your tuner about the Magna Flow mufflers, i was going to do the same thing but he told me to go jap and jap only, so i got an Apexi N1, its not to bad but still quite loud...
i suggested a few 3inch twin muffler systems but i think the attraction from the EPA your getting is becasue of your race cat, i have one as well and the car is quite a bit louder because of it.
I bought a silencer for it on long drives and it shuts it right up and still goes well, but not as well as without it!! just be careful you dont lose any power over the different exaust and have a chat to Ben about it before you chose a different exhuast...
I was just at a local exhaust shop speaking to him about my situation. Some interesting points he made:
- Their are 2 diff types of Magnaflow Cats, 1 has heaps of little 1mm holes and the other has 3mm holes. Provided you get the right size/volume cat it won't impact on flow only sound/noise.
- The rear canons (Jap) are nothing but a pretty hotdog which offer very minimal baffling.
- Their are 2 main types of baffling systems for the typical 'muffler (think; Lukey mufflers). The old style is where the flow pipe bends and twists around inside. The air/gases flow in a way to hit head-on with each other (effectively cancelling out on each other, hence reducing drone/noise but lots of back pressure).
The other type is basically a straight through pipe (enters 1 end of 1 side and exits the other end of the other size - sorta diagonal I spose) but has other parts inside the empty part of the muffler that do all the baffling. So basically the bigger the muffler you can fit under that rear bar the quieter it will be and better overall it will work.
Benm - you should go to a truck exhaust shop and get them to put a v-band flange on your removable section, then it's a case of one bult, a band and you're done!
my trust TR has V-bands and it is easy to remove the rear section :P
The power getters arent supposed to be quiet, I think thats where the Fujitsubo Legalis R  comes in. I had a listen to a few of the sound files on the Fujitsubo site and you can definately tell the difference between the PowerGetter and other models.
^^^ This is correct. Fujitsubo even include tested dB on their website. I can't find a listing for a Powergetter for an R34 GT-T, but here is the R33 GTS-t entry. For those that can't be bothered to click:
(Senario | Stock Exhaust | Powergetter)
Idling | 65 dB | 82 dB
Approach exhaust noise (4800 rpm) | 87 dB | 99 dB
3000rpm | 77 dB | 95 dB
5000rpm | 87 dB | 97 dB
4000rpm - 6000rpm response | 97 dB | 109 dB
The Super Legalis R is a much better choice (and considerably more expensive IIRC).
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
