Recking GTR R33 Vspec
Box= $2000 or best offer
Diff= make offer
Seats= $1000 or best offer
steering wheel= make offer
Brembo brakes= $1500 or best offer
Ive got the whole car minus the motor and turbos, ive used that for my skyline ;) just ask and make an offer. Everything comes with recipts the car was bought from the auctions..
msn = [email protected]
contact Jesse on 0424 976 254
Edited by King
https://www.sau.com.au/forums/topic/100869-recking-gtr-vspec-r33/
the car is located in moore bank sydney. its white, and the rear wheels were 335 wide, the poor bloke wrapped it around a pole that came with car a stop sign. all mechanical running gear is fine. PM me for mobile number can talk more
Edited by King
Diff= make offer
speedo, centre console dials and climate control still availble?
pm me please
Diff= make offer
Ive got the whole car minus the motor and turbos, ive used that for my skyline :( just ask and make an offer. Everything comes with recipts the car was bought from the auctions..
have you got the rear taillights
Ok peoples, i really want to get rid of the box and diff so if anyone is interested ring me my phone number is on the top of the screen and give me an offer.
Ring me if your interested in anything else as im not on these forums all the time and its easier for you and me to talk over the phone.
Thanks
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
