I want to put a turbo kit on my R32 GTR and i want a response car. so if any one can steer me in the right direction that would be great. my r32 is basicly stock has a exhaust. so any other parts that might help me with making a response car please tell
https://www.sau.com.au/forums/topic/100875-gtr-turbo-kit-help/
how responsive are they. what is the rpms a soon as full boost comes on?
http://www.skylinesaustralia.com/forums/in...p?act=Search&f=
cheers.
Its all covered, depends on your engine spec.
Have a read of the threads.
Same thing for 2530's
GTR Garrett 350HP Upgrades
707160-5
pnblight uses them in WA and makes 500+rwhp with supporting mods
They bolt up to all the standard oil and water lines as well as dump pipes
several customers have pointed out, that they see a difference of 3-500rpm
Thanks
Tarek
RACESPEC
this is not the for sale section, traders can use thier own sections freely, not FI
cheers - R31Nismoid
the best two units are
Garret gt2560r 707160-5
Hks 2530
I personally not very interested in the gt-ss as you loss top end with no real gains in the bottom end over the 2530 or gt2560r (personal opinion )
both direct bolt on and both very similar, if i had to pick the differences the garret will spool a little earlier and make a little more hp at lower boost BUT the HKS is capable of high boost and comes in to it own in this area but these not a lot of motors that will run 1.5 bar plus which is where i believe the HKS start to over come the garrets
Racespec can supply the garret at a very good $$ much cheaper thean the hks unit new out of japan (comparing new with new)
I have run the garret turbos through all the stages of my build up from std with exhaust 12.08 1/4 miles (std air box ,injectors,afms, ecu ) to 529.4rwhp at 20 psi
pete
2530's mate...i made over 440AWKW on race fuel and over 400AWKW on pump gas also made 467RWKW on 103unleaded....runs 10.3's and goes like a rocket off the mark..1.4-1.5 60' times...i might have a set for sale if you are interested...pm me
Edited by DiRTgarage
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
