Hi all,
As some of you may know, my uncle owns a camera shop in Sydney and is able to get a lot of goods at supplier/cost price. I have recently purchased a Manfrotto 241v camera mount from them and thought a few others here may be interested.
Basically, the photo above speaks for itself. You'll be able to mount this both inside and outside your of your 'line and either snap/film while you are driving (filming is the goal in my case). Personally, my chosen mounting position/s will be from the windscreen and driver/passenger door. The position shown in the photo is probably not recommended on your Skyline (even with the support leg in place) ;)
Being Manfrotto, quality is assured... the entire unit is made in Italy using really good materials~ Suction is strong enough to lift an office desk complete with PC and Folders :worship:
Straight from Manfrotto Website:
Attaches to most non-porous surfaces. Ideal camera support in automobile or next to a window.
Weight 1.5000 kg
Load capacity 3.0000 kg
* By load they mean the actual camera mass and not the load that can be applied to the suction cup *
Group Buy Details
Start Date: 06/01/2006
Finish Date: 06/02/2006
Normal RRP: $200.00 ~ $225.00 (depending on shop)
Group Buy Price:
$175.00 per unit including GST
Payment:
Payment will be required before the end of this group buy to secure your Manfrotto 241v; this is simply because my uncle does not stock these usually and has to order them in.
Payment method will be via Direct Deposit into my Commonwealth Bank account.
Delivery/Pickup
Local Pickup is available Mon-Sat from my uncle's shop... buyers will be issued with an official document to prove your purhase so you don't look like an idiot when you walk in there :worship:
Delivery interstate can be organized as well, not sure of the pricing for normal registered/express (estimating around $20-$25)
Please note that other Manfrotto accessories / attachments can be sourced as well - if you wish to get it all together; please PM me or post it up here.
Questions or interest, please post up here of PM me.
https://www.sau.com.au/forums/topic/100882-manfrotto-241v-group-buy/
Sorry mate, only just got it during my lunch break today... first test run will be tonight on the cruise :P
I've asked around and there are guys who mount these on during their runs around Wakefield - it seems to be dead steady.
The most "unstable" bit of the unit is the mounting head I would have thought, but they have designed it in 3 pieces with clamps and spring screws - the thing is solid as a rock!
*above statements made whilst mounted on desk*
Real testing in 4 hours :P
If you want more stability, buy a hotshoe bracket, and another suction cup and pole, so it's fixed from the top and bottom.
This is probaly better for DV cameras (obviously), they are lighter, and there isn't much point in having a still camera in the car for trackdays.
Satanic, when you're testing, just use something with an equivalent weight, and drive your car pretty hard, straight line, braking and around corners.
The weight of the camera will surely surpass 3kg with the added g-forces, and you wouldn't want metal poles and a huge chunk of plastic floating around in your car on a track day.
Great info darK!
OK people, testing has been done from Friday night :rolleyes: Great news is that it works perfectly for my Sony Mini DV camcorder. As darK has said, this is way more suited for small camcorders (mini DV) as it is obviously smaller and more light weight!
Only problems so far (more like bitches)
1) The mounting head is not a quick release
2) The angle from the mount needs to be finely adjusted BEFORE you drive/film.
* Quick release would be good so you can take the camera out without having to unscrew everything :(
Not bad indeed. I would prefer one to actually be attached to the floor in the back and to be attached to the roof or to sit on the rear parcel shelf.
Let us know the quality of the shots, I am really intrigued into this.
Is this the best price that can be done??
they are a bit cheaper throught B&H, and as l'm about to order from there, need to see which way will be cheaper.
Edited by [ STAGEN ]
OK here's an update...
Been trying to test this thing in full over the weekend but the weather has been completely screwed up!!! All the footage is clear for like 15minutes, then comes up all blocked by rain/fog :(
I've discovered how you make the head a "quick" release... you put the support stand in before the mounting head :rofl: Still a bit tricky but saves the 15minutes required to set everything up again.
Putting it simply, cost price is $165.00 incl. GST - obviously my uncle is not going to do that for everyone so I guess the lowest people can get them for is $175.00 (small charge for processing, ordering etc.)
If people want them, just let me know... I'll organize a pay-per-unit thing :) if you want them, it'll be $175.00 (pickup)
Happy Days...
Original post changed!
I'd like to see the footage and also a few snaps of how you have got everything setup. EG the suction cap on the window and then is the second support rod just resting on the floor or is it bolted etc.
i am assuming it would clip on if possible????
,8 Jan 2006, 09:55 PM]Is this the best price that can be done??
$97 USD = $128 AUD
+ Shipping
+ Waiting for the order to arrive from America.
I'd say its much more worthwhile to join this group buy.
Satanic, can you post a still shot from the video, or even PM me it, just want to see what kinda angle this has.
Thanks.
Thanks darK
Below are some of the stills from the video I took on Friday night, as stated, weather was crap all weekend so much of it came out rather poorly.
About the angles though, you can pretty much get any type of angle depending on where you mount this thing. I put it in the top left corner of the windscreen to get this angle - it was just the most convenient place for me that night.
post-19974-1136783068.jpgpost-19974-1136783147.jpgpost-19974-1136783175.jpgpost-19974-1136783208.jpg
$97 USD = $128 AUD
+ Shipping
I'd say its much more worthwhile to join this group buy..
Shipping is pretty much n/a as l'm already ordering over 5K worth of equipment, yes its probably more advantageous to still go through B&H.
Though, do we (or can we) get a full tax invoice if we buy from this g/b?? As l'm a 'tog full time its just another tax write off for me.
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
