Hi All,
Anyone know what the X-Force turbo back exhaust systems that JustJap sell are like?
I noticed that they come with an adjustable silencer... Do they cut power down heaps? I'm assuming you would have to balance it between power and noise...
Any feedback is helpful.
Thanks,
Dave.
https://www.sau.com.au/forums/topic/100895-x-force-exhausts/
Ok lets have a look here.. the x-force exhaust is about $600 excluding a CAT.... another $200 for a half decent CAT and another $100 - $200 for fitting... so approx $1000 for a bolt on cheapish system... Personally you could spend approx the same kind of money you can get an exhaust shop to custom make a 3" mandrel bent exhaust, high quality dump and high-flowing CAT and you can also angle the cannon the way you want it... get 2 years warranty and is MUCH better quality... thats my 2 cents...
If your in the sydney area i will be more then happy to help anyone with getting them a great deal on a custom exhaust system from liverpool exhausts... what have you got to lose?? let me know if your intrested..
Regards,
Sarkis
They are good for the price, see link below for a thread I started on the Xforce systems about a year ago - heaps of info and a long review.
http://www.skylinesaustralia.com/forums/in...topic=54115&hl=
Friend had an X-Force titanium on his S15. Not bad for the money, the welds were a bit shit through and after a couple of times of scraping the ground ripped apart. You get what you pay for I guess though, so overall it was pretty good :P
I have a stainless Xforce exhaust on my s15. Because they are a mass produced item the fit is very average. I am going to get a custom cat back made up that will quieten it down and will fit a whole lot better. I just find it a bit noisy as well.
That said, a friend of mines r33 gtr has a 3.5in xforce from the turbo back which is nice and quiet and the note is perfect along with the fit.
If you are planning on purchasing one to run the silencer in it all the time I would stick with a stock exhaust. The level of back pressure the silencer creates can often be more than a stock exhaust.
An exhaust is only as good as its smallest orifice.
FYI - The custom catback I am having made up is mild steel with a stainless cannon and a very high quality straight though centre muffler (which will do almost all the work. Cannons do very little!). Cost is $600.
Hope that helps.
James
I picked up an Xforce turbo back 3" system for $650 including hi flow cat and stainless cannon. Fitting was about another $200.
The silencer cuts down the noise noticeably, but looks like shite. Without the silencer it was tested at *just* under the legal db limit at the specified rpm.
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
