I have some parts off my old GTR that I want to get rid of as Im in a need of quick cash
Original Recaro seat with a BRIDE rail with slight wear. Fits straight into R32 R33 and cefiro $180 (Rail alone costs more than that)
OS Giken twin plate clutch with OS Giken flywheel.
Clutch has about 65% left on the pads. You can still get plenty of use out of it or rebuild it if you want. Very easy clutch to drive. Fits R32 GTR or R33 GTSt
$500
Nardi steering wheel with boss kit for a R32
$140 (boss kit alone costs $80)
2 GoodYear Eagle F1 tyres only been driven on 2-3 times then taken off
my brothers car as the front ones would scrape on the front guards.
Very good tyres cost around 250 new 17inch 45/235
$300 for the pair
KSP engineering 3.5 inch stainless exhaust with 4.5inch tip
has been bent a little from when my car was hit.
Exhaust shop should be able to fix it
$130
post-14428-1136529560.jpgpost-14428-1136528941.jpgpost-14428-1136529035.jpgpost-14428-1136529123.jpgpost-14428-1136529307.jpgpost-14428-1136529640.jpgpost-14428-1136529721.jpg
https://www.sau.com.au/forums/topic/100910-bargain-parts-r32/
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
    • I was just going to say that it's good to see you picking up the pace again. Hope the surgery goes well. More downtime just means more time to come up with new ways of digging a deeper rabbithole
    • How do they compare in size? I have the Yaris coil packs in mine and they work fine. But they are either bigger or sit differently so the engine cover doesn't fit anymore. Not the end of the world but not great either. Do the R35 ones sit flush?
