Hey people. Just a quick question as i've got an rb25det conversion from a sII r33 into my 180sx. :) Just want to know what to do with my intercooler plumbing. As i used to have a ca18det powered 180, i have the intercooler core and bottom arms of the plumbing coming up through the battery hole and the pod filter area on the left and right.
The thing is, im wondering if I should get either a GReddy or Plasmaman Inlet Plenum to shorten the plumbing and make it easier to plumb it all up. As i'm intending to put on a high-mounted GT30R on eventually, i wont be able to have the traditional over the rocker-covers plumbing.
Has anyone run either the bolt up plasmaman plenum head on the stock throttle body and intake runners - or the whole new plenum chamber from GReddy, which i've heard can sap from the mid-range.
Anyway i could also do a cut-and-shut of the stock plenum to have the plumbing in and out, but i haven't heard how this makes the car behave, because im fairly big on drivability.
Any help from the tech-heads is very much appreciated
Cheers
Edited by tuna_144
https://www.sau.com.au/forums/topic/100932-rb25det-plenum-choices/
this is my current set up, theres no room over the top of the engine for the pipes, the hood would never shut. This gives a long way for air to go, but i made it from narrrow exhaust tubing to keep the volume down. its only running 0.7bar on stock tubby now anyway.
(sorry huge pics)
I am going to run gt3071r with supporting mods in a couple of months so have recently ordered a custom plenum creations rb25det plenum. Its a very good price and very good plenum, can run nice short pipes then, yay.
Edited by tom200
can anyone say 'mandrel bends'? LOL
-rb25
:lol: haha, i thought the same.
Check out the ISLEEP Custom Plenum Creation plenum, read the Greedy ones arent the best for even cylinder filling and performance in general.
is that fact or just rumor that the greddy plenums are puss?
wouldnt a major company make sure they flow well without damaging engines.. i just find it hard to belive such a big company would make utter crap if what some people are saying is true??
not having a go ether as i know nothing about the how they all flow... but with the millions of dollars greddy have im sure they could of made a better plenum if there suposidly (crap)..
I think more what they mean is that the GReddy inlet plenum's are designed for performance, and thus are really intended for top-end peak power. From the plenum designs i've seen fitted to nissans (mostly sr's), it appears to rob the car of some low to mid-range power and torque in favour of all-out power.
ive heard alot of reports that no matter what power figure rev range etc, the greddy ones for their money still flow no where near as good as other brands....Ariel can provide u with flow tests to show u...
heres a pic of mine with the 80mm throttle body, can get pics soon when its on the car
ben...
Hey people. Just a quick question as i've got an rb25det conversion from a sII r33 into my 180sx.  :D  Just want to know what to do with my intercooler plumbing. As i used to have a ca18det powered 180, i have the intercooler core and bottom arms of the plumbing coming up through the battery hole and the pod filter area on the left and right.
Cheers
Geezus man, do a search, this subject is done to death...........hundreds of times.
If you are keeping to standard internals then the standard inlet is the best, for everything, max power, average power and throttle response. Want to know why........then try the search button. Want to know how it has been tested? On the car? On the flow bench? Then do a search.
This is one of THE best supported forums in the world, whatever subject you can think of there is a 99.9999% chance that someone thought of it long before you did. There are enough race car engineers, machine shop owners, mechanics, fluid dynamics engineers, etc etc that post on here to have the questions answered years ago.
:D cheers :)
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
    • Did the noise appear after your sand trap adventure? Could be something got dislodged and is playing rub rub. Even a rock wedged somewhere.
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
