I was just wondering if any one out there has rebuilt there stock turbo?
I am sick of worrying about the ceramic turbo and was thinking about rebuilding it as i don't want to break the bank and get a new one.
How much would this cos?
What benefits?
What would be done to the turbo?
Thanks heaps guys...
https://www.sau.com.au/forums/topic/10094-rebuilding-stock-turbo/
G'day blx,
Why are you worried about destroying the ceramic wheel? How much boost are you running? What sort of hp figure are you chasing.
If you want to run higher boost, say above 12-14lbs, then it may be a good idea. If you are happy with 10lbs with a stock coola, or 12-14 with a front mount, your turbo is probably quite safe (I say probably because there are never any guarantees.).
If you do want to do a rebuild, just remeber you get what you pay for - I have heard of a few horror stories - so do a bit of research, be ready to pay $2k+ for a decent job, roughly, you may get it done cheaper, but it depends on what exactly you are chasing.
If you want to have a look at some rebuild options, gcg have a website with a couple of rebuilt R33 turbo packages, which members on this site have spoken highly of.
The main thing to consider here is what sort of performance you are after from the car, and if you want more than the stock turbo will provide, get it upgraded then. for example I have just over 200rwkw on the stock turbo, which is about the limit, but if its enough for you upgrading the turbo would be a waste of money IMHO
Steve
Gday blx
Lot of info on this topic if you search for it.....
But basically besides what Steve has justy mentioned,
you have alot of variables here u havent told us like what u want out of it and how much u want to spend...
Considering u put steel/alluminium wheels back in this straight away introduces lag because of the increased weight.
The ball bearing cores dont seem to be rebuildable! Even tho ppl say they are, what they usually do is bolt your covers and new wheels onto a new core!
I have had my turbo's re built twice, at Garrett at Chipping Norton Syd.
It costs $350 to clean and reseal each turbo.
To high flow turbo from 43mm compressor wheel to 47.5 mm $200
To replace compressor wheel $600.
Steel shaft kit was I think $400.
I think that鈥檚 about right. Look them up or ask for there number at anyone of the performance shops, but really looking at those costs it would have been best to but an after market HKS 2535 or similar Ball bearing turbo.
You can get a number of good 2nd hand bb turbo for around $2000 which seem to be about the same price as a good highflow job anyway.
While highflow is tempting, an aftermarket turbo that has been fully engineered the way it is for xxx HP seems to make more sense to me. Hiflowing seems to be a bit hit and miss from people who have had it done. Some people get good results and swear by it, others end up having to get theirs rebuilt a 2nd time because something has failed.
Originally posted by Doctor
Go aftermarket as you get a better turbo and then you can sell your stock one and get some $ back on your new purchase.
Doc has hit the nail on the head.
Get a second hand turbo (HKS 2535 would be nice :) ) for around the $2-2000 mark, then if your stock one is in good shape you might get $5-600 for it.
Sweeeetttttt.....
