This may be a repost but I wanted to give everyone a heads up on this...
I came across this video on another forum: [warning - 24mb]
http://www.crazycarvids.com/showvideo.php?id=335
Its about the use of everyday walkie talkies to interfere with the car alarm signals. Apparently thieves in Germany are using it to get easy access to cars where the owners just press the button and walk away without checking to see the doors are locked.
Alarms and walkie talkies work on the same frequency. This works on all types of cars and alarms even BMW and Porsches. Check it!
https://www.sau.com.au/forums/topic/100940-take-care-when-locking-your-car/
those detachable kits are becoming cheap now too... no need for sterring wheel lock.....
haha go out to dinner with the gf in one arm and sterring wheel in the other :)
I would do this if my car did not have airbags
You could probably just chuck the wheel in the boot.
The mere sight of no steering wheel would deter most car thieves.
I dont know about the rest of you but sometimes whn i lock my car the alarm starts going off for no reason. I just wondering if it happens to anyone else, one of my mates seems to think that it is because the car is still running and the vibrations set of the alarm.
sounds like ur shock sensor is too sensitive, my mates TT soarer would set off the alarm when it was idling with the turbo timer on.
just adjust it so its not so sensitive. if your cars idle sets it off then it probably means other cars with loud exhausts driving past will set it off too.
Some car alarms set themselves off in the hot weather due to an expansion of air inside the cabin.
Sensors read this as movement, and set the alarm off.
It can sometimes be remedied by cracking open a window a few mm, but relates back to that COGS said about sensitivity settings.
I love driving around the underground car parks and setting car alarms off with my exhaust note...
Nobody pays attention to car alarms any more.
People don't even want to look in the direction where an alarm is going off, in case they see someone stealing a car.
People don't want to be inconvenienced by seeing something which may require that they waste their time and lose wages by having to make a court appearance because some asshat wanted a free ride.
We discovered this one first hand when the batteries in the remote died...
crowded car park, we open the car manually due to being unable to disarm the alarm, the alarm goes off and keeps going off.... people walk on by, but don't look in the direction the noise is coming from!
Even while someone had his head under the dash with legs poking out the door trying to find the fuse to shut the siren up, people just continued to pass on by.
again....... nobody cares about alarms.
visual deterrents is where it's at.
I'd love to get one of those detatcheable steering wheels but my gf would refuse to carry it around in her bag while we are at the shops. She already carries around my stereo face and sometimes keys, imagine a steering wheel as well! :lol: I always check to see if the doors have locked after I leave as well.
"I'm somewhere where I don't know where I am!"
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
