insurence for 34 n/a on a 17yr old
  • Replies 65
Yes it is relatively easy!
I knew someone who failed it 9 times in Victoria...so don't be hard on yourself if you don't get it first go thats all [i think thats what 87vlt meant].
If you have studied then you will pass ~ like most tests really :)
I didn't even know there was a book and just did the test. Failed first time by one question. They go over everything your not sure and explain the question at the counter which is awesome. Cause she told me enough to pass. Biggest thing was always give way to anything on your right. You should also go for your Learner's Motorbike license to as its only 5 more questions which are VERY easy :(
Good luck!
Thankyou for clearing that up Chaos ..... now for my reaction ... W-w-w-w-w- wHaattt THE ?
I mean I thought maybe the whole not getting insurance before the car thing was a little crazy ... but I've never heard of someone getting a car before they even have the most basic form of license.
I don't get it :P
Just make sure you book in ASAP for the next one, dont let it bother you / get you down ~ as many have said, a lot of people before you have failed also.
I am sure you want to get your license with a car like that!!!
Good luck for next time :D
    • There's more than one way to skin that cat, and most of the sump Maatouks have done will be GTR sumps. They are HUGE in GTR drag racing here.
    • Yeah...I always start at the shift solenoids, because there's only a few reasons these will spook into limp mode, and bad shift solenoids is one ~ the other can be the shift control module (if you have steering wheel shift buttons)...it's easier to eliminate the solenoids first.
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 😅
    • Thank you, this will keep me busy for a bit.  I will update progression.
    • That specific one would be an exchange part, meaning I'd have to send mine to them. Plus it looks like a non AWD sump, which won't work for me. There is one or two shops in my country that I can ask to do a sump extension job and it'd most likely end up being cheaper than sending mine to AUS or NZ and getting one back, and quicker too.
