Got a rb30 block sitting in my carport, was from a rb25/30 combo has all internals/sump (prolly rb25 sump as fins are trimmed to allow crank clearance), and water/oil pump. The bores have surface rust due the being open to the air. But if you going to rebuild it that aint going to matter anywho.
All the above for FREE!
I even have an engine crane to lift it on to your ute/trailor etc... need to get rid of it simply cause my dad getting sooky about is and saying:
All your sh!t is in the way!!
Which is so wrong cause his stuff takes up much more room lol. Either way has to go as i wont ever get around to using it.
Cheers
G
Edited by geordie
https://www.sau.com.au/forums/topic/100993-something-for-free/
i'll take it please, can pick it up this afternoon.
can you send me your number, or call 0412 877 433.
thanks
Mark.
Sorry bud, was working all night. Will call you tomorrow morning (which may be closer to lunch pending on when i wake up :rolleyes:.
Cheers
G
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
