  • Replies 73
actually my 3" pipe is silent... i reckon it would scrape under the 90db mark it honestly isnt that lud at all.
as for stickers... the only stickers going on my car will be the SAU VIC stickers we end up making.
https://www.sau.com.au/forums/topic/10100-coppas-everywhere/#findComment-158057
Hey Inark,
What 3" exhaust u got? I got Trust MX... I read the spec that the tip diameter is the same with Apexi N1, so was wondering if the N1 optional silencer will fit in nicely in the Trust MX? (Just need to drill a hole in the tip to hook up the silencer)
I actually don't think my exhaust too loud, but it should be able to make it quieter whenever you don't wanna attract too much attention.
https://www.sau.com.au/forums/topic/10100-coppas-everywhere/#findComment-160285
Originally posted by pushead
i heard they superglue it onto the glass and you need some 'special chemicals' to get it off....
trust me i have done this before!
u just scrape it off then use sum bug and tar remover to clean the glue off! It can be taken off quite easily!
https://www.sau.com.au/forums/topic/10100-coppas-everywhere/#findComment-160372
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
    • 4 not at fault claims in the past 5 or so years (lucky me...). 2 windscreen replacements from rock chips. Didn't pay a cent on any of these.  All claims processed quickly, hire care sorted, an overall very good experience.  I haven't had any curveballs to test shannons with though. My claims were very much, here are all the other persons details, they have full comp insurance, etc.
    • Personally I would first drain the oil thats in the sump.. and stick something else in.. something cheap.. which id then replace once its idled for a wee bit. Fogging oil is usually done before you put it away - I use that on mine.. as I store it for a whole year every year. Your injectors might be stuck, if running an aftermarket ecu you can easily test each one.
