Ai*MADAZ i hardly play though but if ever u want to come say hello in ventrilo 1.4 your more than welcome
if you dont have to older version thats ok click here
server is OGN 2
ip is 203.206.95.15
Port is 3771
i can setup a subchannel in my clans channel to have a SAU meeting place with a SAU only password
if u have newer versions of ventrilo that is ok ive renamed the vent.exe file accordingly so u can stick it in the same directory as say ventrilo 2.2.0 or 2.3.0 ;) u can run multiple versions on the 1 machine @ any 1 time
Jesus Christ dude.......you speaka de engerish!!! :D
  • Replies 426
Posted Images
;) just a little <_<
i tried not to get too technical
d/l it and see if u can follow those instructions and come say ello
**EDIT**
btw im in a subchannel near the bottom called ai and my nick is Madaz funny enough
Edited by Madaz
naw i dont use TS dont like it my old clan had a TS channel ive used xfire but not any more
yes u can search for my name as the server channel list isnt very big
and i wont be on for a few hours even :D
ok ive just made 2 channels in my teams main channel
SAU members can use them to have voice chat
the SAU members channel is passworded so maybee PM me or just chill in
the SAU lobby till u find me
Edited by Madaz
good man looks like u got alot of PMing to do :(
when uve pm'ed every1 make a list in ur post and ppls can easily see if there on the list
you know the naughty and nice list :P
Edited by Madaz
    • I mean, I can confirm the TPS is at 100%.... I can confirm when we installed the TB and setup the cable that the TB was indeed fully open at max pedal travel.. the same 'curve' (WRT MAP vs MAP) existed with the previous setup/TB/manifold as well... No, we did not do a run with no intake connected. I would love to go back in time to do such a run to rule out the intake. It would have also been good to do a run with the airbox lid off. There's a test there where increased IAT vs more available air could be a positive tradeoff. I remember taking the lid off my R34 Turbo setup back in the day and noticing a monster increase, even if IAT's did go up. Could be similar. Hard to test unless I find a very deserted road.
    • That's actually encouraging to be honest. my motor was rebuild many years ago but it's probably done less than 30,000kms and fucc all limiter or drift, majority street / drag / roll racing. It'll be fine 馃挭馃徏 I don't even have lines or a can for the cam breathers installed yet, there is zero oil residue or splatter on or around them, it drives beautifully so it seems healthy. Just a ticky lifter, yet they're almost brand new oem genuine Nissan and haven't done many kms at all...
    • Have you confirmed the throttle body goes to WOT (and stays there) during the run?
    • I'm having a problem. I think it was mentioned above somewhere but can't see it.  I'm stuck in the cycle of, sand, filler, low spot again, put filler, sand, low spot again, now i put filler again and a thicker portion which seems to have helped but I got low spots in other areas. In the image. Circled in red thats where the original low spot was and the shape is the same as the red out line. I've more or less fixed that (still low spot up the top but now I have low spots where the green circled part is.  Is likely the issue that I didn't start with a course sand paper? I sanded the filler with 240 to reduce the risk of not going to far but maybe the issue is that I'm only taking off enough material to remove some of the filler but not the high spots. I now started sanding with 120 and I think I'm seeing a difference. I did fix one dent the other 2 are f**ked and seems like I made another low spot which is indicated by the furthest green circle on the left handside. Any thoughts and solutions?   Also second image. All of these rock chips, can they be filled in with primer or do i need to fill them all with filler/putty? So many rock chips on mine lol.
    • Well, I had an Edward Lee's special edition odo windback car/motor with a RB25DET S2 and I put down 372kW with a good amount of track abuse for 1.5 years before the ring lands decided it didn't want to stick around anymore 馃ゲ But probably didn't help I kept on smashing try limiter on the track and a few skid pans.
