Ai*MADAZ i hardly play though but if ever u want to come say hello in ventrilo 1.4 your more than welcome
if you dont have to older version thats ok click here
server is OGN 2
ip is 203.206.95.15
Port is 3771
i can setup a subchannel in my clans channel to have a SAU meeting place with a SAU only password
if u have newer versions of ventrilo that is ok ive renamed the vent.exe file accordingly so u can stick it in the same directory as say ventrilo 2.2.0 or 2.3.0 ;) u can run multiple versions on the 1 machine @ any 1 time
Jesus Christ dude.......you speaka de engerish!!! :D
  • Replies 426
Posted Images
;) just a little <_<
i tried not to get too technical
d/l it and see if u can follow those instructions and come say ello
**EDIT**
btw im in a subchannel near the bottom called ai and my nick is Madaz funny enough
Edited by Madaz
naw i dont use TS dont like it my old clan had a TS channel ive used xfire but not any more
yes u can search for my name as the server channel list isnt very big
and i wont be on for a few hours even :D
ok ive just made 2 channels in my teams main channel
SAU members can use them to have voice chat
the SAU members channel is passworded so maybee PM me or just chill in
the SAU lobby till u find me
Edited by Madaz
good man looks like u got alot of PMing to do :(
when uve pm'ed every1 make a list in ur post and ppls can easily see if there on the list
you know the naughty and nice list :P
Edited by Madaz
    • Which model Maxima? This is good knowledge to have.
    • I'm with GTS, that's not an actual overheat issue. That's an electrical issue.
    • So, it's clearly an electrical problem. Either with the gauge itself, or the sender. It appears to be voltage sensitive (ie, alternator output affects the reading.
    • Yes, at this stage of SAU threads, I  automatically assume that anyone here knows that everything depends on each and every setup and its choice of parts and what an individual wants from the setup. I think your misunderstanding what I've said, I'm not saying your curve will move to the right.. I'm stating the opposite; that my setup has a much larger turbo than my last one, my current exhaust manifold runners are 2-3x longer than the last one, the intercooler is longer and thicker (hks 103mm thick), the itbs are now oversized from 45mm up to 49mm, and the plenum is now a larger Nismo plenum that's been port matched. As a result, I'm making more power, torque and boost 1000rpm earlier than my last setup. My curve moved left, in a big way. You guys with 800-1000+hp turbos should be considering hks v-cam or the other Japanese company Sakura who makes RB25 Neo vct adaptor kits for RB26's. they all make more power / boost / torque far earlier and higher peak numbers. Dahtone Racing modifies the Hks v-cam systems to his own specs and he also developed the worlds first and best dbw individual throttle body kits, to complement his V-cam. Every single car is 800-1200+hp and they all produce huge gains in response and peak power.
    • I have a 2008 Skyline 370gt with about 160,000 km on the clock currently. A while ago, I noticed the temp gauge would start climbing but it comes down when I give it some throttle. I took it into the shops. The technicians comments are transcripted below. Reported they couldn't find anything wrong with the vehicle mechanically and they pressure tested the cooling system. Funnily enough, the technician commented that the temperature dropped back down when the car is stationary but this is when I'd notice the temp gauge to be climbing. Just wondering if anyone else experienced anything similar to enlighten me? Cos at the onset, the temps were going up one tick and then comes back down when I step on it. Now, the temps are climbing all the way to the top of the gauge, and it's making me very nervous lol. It also doesn't come down to the neutral position anymore. PS I do have a small exhaust leak near the drivers side caused by when I got f**ked by a really steep driveway at a mall I never visited before. Not sure if this would affect the sensor. Technician comments: Check and verify Fan/Cooling system - ALL OK max 106*C and fans operating at 100% Cools down right away. Checked Fan Operation - 55%@101*C, 85% @ 104*C and 100% @ 105*C Vehicle did not exceed these temperatures with max load. Temperature recovered back to 99*C after fan operation while vehicle Stationary.
