  • Replies 426
Posted Images
Madaz,
You missed myself. :P
minor oversight soz :D
**Updated List**
PPLS that have registered there interest in comming
HR-32
Madaz + 1 and posibly another + 1
DriftR_33
mr_rbman
vange
GFXman
DC_GTST + 1
Deluxe
black33_26
writeoff
Turbz_13 (will meet us there, a VH cronie)
heslo
Oosh
r31turbo
dangerman4
Maxx
9krpm
Cubes
Sambo33
any 1 know about Iceduc, Busky2k ,66 skyline gt or any the other locals @ these boards
yep put me down if my 34 is ready by then (it'd better be!)
It's funny - there seems to be a changing of the guard with Munro and Cheeky married/pregnant, Mel and Pawley just had a baby *congratulations*, Joel with recent addition, Whatsisname busy doing other things, Grepin overseas, Buggalugs m.i.a, myself inbetween cars .... seems most of the old gang have disappeared. Of course some of the original group like Maxx, GFXMan, 9krpm, etc are still quite active. Ah well, I suppose it's the change of times. :unsure:
Well so much for my 'Welcome the R34' cruise to Victor with paintball or go-karting, that I was going to plan for February - might have to make it March.
geez i reckon, get your shit together you slacker :blink:
I wont have a licence then unfortunately !!!!! Wouldnt mind grabbing a lift with someone if possible?
I reckon we'll work summin out. Where bouts you live again?
Advertisement Break!
Four Door Turbo Taxi Services
Contact Oosh on...
Edited by Oosh
not sure if can make it, but will try my hardest and hopefully they will roster me off, or my cold might just kick in. Might be bringing a friend along with a 34, not a definate but could join as well.
By the time you get that car on the road, 34s will be old school
I'ts a ploy to be ready in case they re-introduce the 15 year rule again, and Andrew is going to have the first R34 complied under that system :( (hope the paintwork holds up, it will probably be faded by the time its complied)
I'ts a ploy to be ready in case they re-introduce the 15 year rule again, and Andrew is going to have the first R34 complied under that system :P (hope the paintwork holds up, it will probably be faded by the time its complied)
Ouch! That's rough. :)
Contact Oosh on...
Unfortunately Ash i live on a property out the back of woodside in adelaide hills.
Due to licence disqual on feb 1st for one year i will be moving in to the city area (hopefully somewhere close to work). So hoepfully i will be living in city at time of cruise (may even consider letting someone else drive my car with me init like GF.) Will keep you posted!
Oh yeah... got my car back last night: had to get the exhaust maniffold studs put in as a lot of them had been snapped off from warping due to trubo heat and as a result it started sounding like a VW combi van!: THank Fruck it is fixed!!!!! :huh:
fingers crossed u can get sumthing sorted out ...
i would suggest ur GF driving is a good idea ... unless she scares u behind the wheel of her barina :rofl:
I have never let her drive it b4 (i normally attempt to change subject quickly when the topic pops up)... and yes scares the absoulute crap out of me when she drives her little laser with me init!!!! :P
still.... i wouldnt miss the cruise for the world!!! :w00t:
I have a friend in an R31 GTS (aus delivered one of 200 built) that may be keen for cruise as well... will have to let him know about it (i dont think he is on the forums)
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
