Hi All,
I have a set of rims for sale. If you're serious about grip and circuit racing, these are the babies for you.
They are a set of 5-spoke White SSR Integrals forged rims.
FRONT
17x8" 32mm offset (16lb rim - as light as the Volk TE37, or VERY close) with BRAND NEW 205/40/17 Kumho VictorRacer V700 semi-slicks
(as grippy as your to your Bridgestone RE540s and road legal)
REAR
17x9" 38mm offset (18lb rim) with 95%+ tread 255/40/17 Falken Azenis RT215 semi-slicks.
They're off my 1996 MR2 turbo. They fit PERFECTLY on my car which has no suspension mods. (ie. Standard Bilstein shocks and MR2 springs - std height).
The fronts fit snug/flush and never scrubs.
The rears fit snug also also but if you go over large bumps you will scrub if you havent rolled your guards.. After I rolled my guards the next day, they stopped scrubbing..
I bought the front tyres last week and the rears about 2months ago (With Receipts) but have taken the rims off because I didnt want to drive on the brand new fronts yet.
Rims have a couple of very minor scratches but u wont see them until you stand 20cm away. They balance perfectly even at high speeds. No vibrations at all.
I want $2000 for them and am located in Melbourne, Victoria
Here's a pic for those interested and my email [email protected] if you want more information.
http://www.geocities.com/mrgze/Wheels.JPG
Reason for sale: family reasons
You can also contact me on 0416261549 if you need any more information
Cheers
John
https://www.sau.com.au/forums/topic/101039-fs-17-forged-rims-with-semi-slicks/
  • 1 month later...
i have a set of 18x8's of these in silver but wanting ur 17's as i have full slicks. interested in a swap plus cash adjustment?
unfortunately I am not looking for a swap as I already have a set of street wheels, these ones were intended for track use, but doesn't look like I am going to be hitting the track any time soon so they need a better home. Thanks for the interest let me know if you are interested in a straight purchase.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
