  • Replies 71
If we need a minimum of 6 cars, and this is a "bling" event, id suggest that we first use the sort of skylines that Autosalon aims at ("blinging")
Ill have a new interior by then also, its white suede with grey leather
Cant be hard to get 6 good looking skylines
Would also be good to get a variety, R32 R33 R34 gtst's and gtrs
Either way, im in
Either way, im in
Not a bad idea....
but poor Mr Stagea :O
Hey Jago. just a quick question. How long is that inlet system you have?is that custom?
everything is custom mate, no kits for the 31, for anything really (or are hard to come by and expensive)
As for autosalon, i wouldn't mind goin, just gotta fix up some paint tho, it aint 100% show grade but hey, it's different
Where have you been @ phil.
Whats going on with the car.
yea i just been here and there mate, haven't seen you around much either :(
As for the car, just came out of the workshop, fixing a heater hose, which caused major overheating. High pressure hose power steering leak, screwed sump plug, fitted bigger injectors, upped the boost and dyno tuned the microtech. Ran 182rwkw on the autosport engineering dyno @ 13psi, peak power at 7000rpm ;)
What bout u man? or u keep her the same? nice lookin 33 i must say
Man this seems to be getting serious... Definitely count ME in!!!!!!!
After all.. I'm probably teh biggest RICER in here...
BLING.. check
PAINTWORK.. check
LED underbody and interior.. check
AND
NO IMPULS.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
