Hi all,
The coating on my wheels has been bubbling and flaking off in places since I've had the car.
It's kinda annoying me so I was wondering if anyone has advice:
1. Ignore and don't worry
2. Get them sand-blasted and powder-coated
3. Other options? Wheel repair/reconditioning places???
Option 2 is probably sensible but - wank factor aside - I'd like to retain the Nismo logos if I can...
If anyone knows of somewhere reliable in Brisbane to get this done, the advice would be appreciated, thanks! :rolleyes: Pics attached.
https://www.sau.com.au/forums/topic/101060-getting-wheels-re-coatedrepaired/
I am relying on a 5 year memory but Chris Neil from Wheel Revolution.
Unit 2/18 Randall St Slacks Creek.
He's the man to see.
I second Chris as well. Yes he' still there and I've used him before. He's even got a write up in the current issue of HPI, go have a read. Depending on the damage repair work starts at around $40 per rim. He has the ability to bring your wheels up to brand new condition...if I had Nismo's I'd definately spend the $$.
Hi all,
If anyone knows of somewhere reliable in Brisbane to get this done, the advice would be appreciated, thanks!  :mellow:  Pics attached.
Hey jamac go with a wheel shop or panel beater, don't get the wheels powder coated just have them painted in enamel (sp?).
They will not build up the dust as quick & r a lot easyer to clean when in enamel...
enamel your joking rite ?? :mellow: I wouldn't paint my dog kennel in it, thats if I had a dog kennel. 2pak or powder coat only
the guy at street art wheels up here at kunda park has been toying with a chrome finish for wheels for a few years now, not sure how he does it but he also does scratch and repair of mag wheels and repaints them in any colour u like. its called
"StreetArt Wheels,
1/ 33 Enterprise St Kunda Park QLD 4556
ph: (07) 5477 0240 Wheels & Rims--Automotive
Edited by 85URK
The HPI article only touched on rim repairing but overall they provide wheel restoration as well which includes painting. I had a set of Volks that had stone chips and gutter rash and all they did was restored it and repainted it in its original color...came out brand spanking new!
lmao go right ahead & spray your wheel in 2pac lmao if u got the $$$$ & powder coat tends to make the brake dust build up of the wheels more done it my self so know about it enamel is easy to fix if u get chips & is not to costly it depends on u if your going to use the wheels on a show car & have the money to get em done in 2pac go for it or if money is a problem go for the powder coat or enamel ....
ever heard of a fullstop dude lmao! :mellow:
For machining, buckles, gutter rash etc: Dean at Depulu in Ashmore
For refinishing, painting and polishing: Dean at Mag Wheel Services in Southport.
I have personally used both these guys on more than one occasion and they are great at what they do. I absolutely swear by these guys!
I also take my wheels to Depulu for balancing, although they don't really do this as a service, they're the only place that seem to be able to get it right and are usually happy to do a balance only job. Also its noteworthy that these guys never use rattle guns.
-rb25
Edited by rb25
2pak is not that much different from enamels price range because enamel is on its way out and going up in price.There lots of cheap 2pak out there thats better then enamel
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
