As you come off the throttle it uses load points that have most probably not been tuned, as a result slightly detonating.
This is very hard to replicate on the dyno, one good reason the car must be taken for a street run to ensure everything is a.o.k.
One easy fix is to rip out 5degree's. If it does it thenyou know she's running a little too much ign. timing in the cells above the cells that wot uses.
Edited by Cubes
as cubes said when you back off the throttle and clutch in theres a brief moment where the airflow meter "load" will drop but revs will at the same range so youll be in cell area say 15 across ish and 4 or 5 down which wont be tuned. a map trace would easily show you which cells and then you could just take out a few degrees there
No i am not hitting rev limiter, and it is slightly rectified when i quick shift, yes.
So obviously my tuner hasnt done a proper job? He should fix this free of charge? i just got the PFC n tune on friday...
As I said earlier.. its pretty hard to get it spot on unless you take it for a good road test, which many tuners don't. Even then under some rare circumstances such as brisk hills driving you may find your self using a load point that isn't usually used as a result it may have a slightly higher detonation reading.
Its hard to get it spot on. Takes time and tweaking.
Fair enough, we took it for a road test though with the laptop connected doing a map trace, no green highlighted sections... at one stage knock went up to 88 (not while tuning this was last night)
Edited by Suspense
When changing gears i get a KNock spike on my PFC of about 60~80 sometimes...
Is this spike in between gear changes normal, or is something wrong?
Knock with throttle closed is irrelevant, no engine damage possible. Move on.
:D cheers :D
Most off us roll off the throttle quickly, we don't simply jump off it having it completely closed within a couple ms, I had to drop 2 degree's from the 2 load points above the load points used at WOT, around 3000-3500rpm from memory.
If I were to change and slap the gears quick i would not experience high knock readings. At first I suspected fuel injectors but it wasn't.
Edited by Cubes
hey got a queston simlair topic any replies appricates with my power fc when running down through the gear ie engin breaking i get quite high knock ratings ie 40 withc is much highte then even when ime on it hard i get readings of like 15 thanks guys for your replys
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
