I wanted to go out this weekend (14th) but the street series is on.
Anyone interested in heading out for the test and tune?(sat 21 jan)
Finally got my car sorted - will be coming from the north side so am just wondering if anyone's interested in meeting up and heading out in a bit of a convoy?
Would be good to get a few lines out - but I'm not fussed with what people drive!
Cheers
EDIT
ALSO AM GOING OUT FOR THE STREET SERIES (14TH) IF ANYONE'S INTERESTED
Edited by gtst25
https://www.sau.com.au/forums/topic/101065-test-and-tune-saturday-21st-jan/
Sorry can't go then as I'm from Gympie and can't make it.
I am thinking about going this saturday though for the street series as you can get a day pass if you don't have an ANDRA licence.
http://www.willowbank-raceway.com.au/
Fellas I just checked out the prices to enter in the street series and it's the normal 36 dollars plus 5 dollars if you don't have the andra licence.
The next one will be on sat the 14th (this sat) and I'll be going as I'm desperate to run with my new mods.
You have to be out there between 2:30pm and 6 to qualify.
Regardless I'll also be heading out on the 21st althogh it might be a bit far away for people to plan.
Cheers
Not too sure how easy it is to run against someone you want to in the street series. (11th)
I suggest you check out their website - I've only ever been to a test and tune and it was pretty easy to line up against a friend.
I just want to do a few passes and see how the new turbo setup goes.
Cheers
Lets sort this out...
Street Series is on Saturday 14th, and lining up against your mates is really not he priority here and the officials with just look at you strange.
The T&T which is on Wednesday as in tomorrow, the 11th of January 2006 you can line up against mates, easiest way is to be in the stage lanes one behind each other then you can let the officials know that you want to run against each other...
for other events go here...
thanks
Cheers, thats what I wanted to know. Thanks. I thought it would be something like that. :)
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
