Hey guys, got my R33 about a month ago now and I'm so happy with the car, I just LOVE it. Problem is I got an amp and have NO idea where I should mount it in the back. I've seen all these pictures with peoples exotic setups and while I'd love to do that I just don't have the time at the moment. So if anyone has some ideas as to the best placement that I can have at the moment, by all means, let me know :mellow:
Thanks
https://www.sau.com.au/forums/topic/101118-where-to-mount-my-amp/
Dezz, yeah mate, got a sub in the back too, that actually sounds like a pretty decent idea, then I just have to get some angle brackets or something similar to keep the sub+amp from moving around in the back.
On the other hand, that looks quite a nice setup MintR33, seems pretty simple to do also but I may have the problem that my amp is too long to fit in the way that you have it, I'm not 100% sure but will check that tomorrow morning.
Thanks for the ideas fellas, I'll have a poke around tomorrow (got a day off!!! :rofl:) and see what eventuates
Randy, I'd like that if you could pass it on, but how long will it take before you let me know about your idea?
Well actually it's what d00dz has done. I'm measuring up all the sides of that partition, and working out a way to secure the mdf. My other problem is that my 12" Sony sub won't fit where I want it.
I was going to have the amp mounted to the left side, and the sub on the right, with the magnet of the sub poking into the empty space next to the battery. It's too big and doesn't clear my strut-brace.
d00dz... would you mind posting up a picture of your install and explaining how you mounted the mdf to the car? I'm looking for a way that doesn't involve drilling new holes in the boot.
Cheers!
Sorry mate, ive been flat out at work and comming home really late.. and no time/sun to take some pics.. Will try and do so in the next few days or so.
Basically its attatched to some L shaped brackets, the MDF board thingy that is. The L is attached to the metal beneath/behind the plastic divider.
d00dz... I figured as much. I was looking at a way where I can reuse the brackets that hold the plastic cover in place. They don't feel strong enough to hold thick MDF, a heavy amp, and a 12 or 10" sub.
I want it to be very removeable too, so that means minimum tools to get to the battery and service cover.
Can't wait to see your install! Maybe instead of a "how much money did you spend on audio stuff" thread, we should start a "post pics of your custom install" thread? =-D
hehe, mines nothing special.. its actually pretty gay IMO. not at all a good setup..
JVC mp3 unit from my old car
6" front and rears
Jaycar 4x130W amp (awesome and cheap one)
SONY sub (cost 50$ from a dude who only used it in his appartment).
Yea the MDF i have now is pretty hard to get to. Well two screws on either side of the bracket.
Im still not home, reckon wont get to take pics untill maybe tommorrow at 7, if the light is good... or ill just use my flash..
ill see... sorry for keeping you. ;)
Hey no drama's... i'm still sussing the situation out. If I can mount the MDF and I DIDN'T have a rear strut-brace, i'd be set cause my 12" would fit perfectly.
I'm looking at 10" subs now, to see if they'll clear the strut brace. Still looking around to see what mounting points I can use, then I'll write up a guide as I build mine.
Made my own parcel shelf too... looks so damn good that you would NEVER pick that it's stock apart from the big bolt-heads and washers where the child restrains were.
Surely you run the power cables through the other side of the boot lining? It looks too visible through that hole, but otherwise the plank of MDF looks good where it is! I was going to do that with the sub on one side and the amp on the other, but I couldn't see how to mount the MDF securely. Any chance of pics of the actual mounting?
I did that in my first car... moving the seat back and forth was a biatch.
My current and future amps are too large to go under there, plus it'd impede the airflow from the A/C vents under the seat, and then there's the wiring for the belt-buckle that would get in the way. =-]
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
    • Just wanted to say thank you for your input   my man (lead mechanic by trade) and I have done a heap of work as you can imagine just to make the hot side work with the dump pipe, stupid massive intake on turbo, trying to get the waste gate on was not fun.  I’m kinda getting to the point where I don’t know if I try and make this work and not throw all this cash and time away or do I scrap the lot and start again? the Apexi I’ve got was tuned for a few slight differences:   Tomei pon cams (mine are stock neo) Turbo smart 38mm external waste gate (mines 45mm replumbed) with stainless screamer pipe  3inch turbo back exhaust with high flow cat Sard 800cc top feed injectors Sard adjustable fuel pressure reg
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
