is that a custom made back wall yeah? the factory 1 is too weak to hold amps?
any 1 got any ideas for somone with a strut brace...2 amps, and a 12" sub?
yep it is..
its made from MDF.. with the carpet type material covreing it.
Well.. that's exactly what i'm planning to build!
Dezz.. that should work for you. The back part has enough surface area to hold two amps. I'm going to make a hole on the right-hand side to fit the sub. With the strut-brace, it won't hold a 12", but i'm looking for 10" atm.
gw d00dz!
ill be boxing the 12" and putting it in the boot probably off to the side. the factory wall wont hold 2 amps from what ive been told. im not going to take off my strut brace though, so id either have to work out a way to put a fake wall over the factory 1 while keeping the strut brace, or do a false floor and have the amps under it...
dezz do what i did, rip out the side flooring stuff and build a box (up to the manufactures requirements) and fit it in the corner/s (if you have 2 12" like me)
then put the amps in an amp rack on the right side of the battery, then put the divider back in and hey presto!
i'll get some pics for ya soonly
wellat the moment.. zip ties :D... LOL! but back when that photo was taken i used the factory wall mount to secure the new wall.. although after several months and some heavy cornering.. the facotry wall mount snapped.. so i dont advise using this.. especially if you have heavy amps lol
but at the moment im working on making brackets for it to screw into the roof of the boot like the pics above posted by d00dz i think it was
even with my setup, i still have enough room in the boot to put a large rectangular bag to go away somewhere ... so its still fairly roomy (considering how much was there to begin with.. also my sub can be removed in under 10 seconds... so if i need the space its no big deal!
What ever you do, don't mount the amp onto the sub box as when you get those deep bass beats you'll rattle the internals out of the amp. If your looking to mount it somewhere to keep the max boot space and keeping the look sleek mount it under the front seat(passengers side).
Not entirely a problem these days. Amps are built pretty well and you'll get vibrations anywhere it goes simply from driving the car.
Well.. I made the battery-cover idea that I had illustrated earlier.
Used 1200x600x12 MDF. Trimmed it down to size, cut off the angle piece, got some 90 degree brackets and bent them to something like 20 degrees, reattached the angled piece, drilled out the bolt-holes and it fits.
Only problem now is either spot-welding the nuts to the back of the stock mounts or working out some other way of bolting/unbolting the damn thing.
The bottom sits perfectly on my spare tyre, nice and tight... so hopefully it won't vibrate against the metal anywhere.
I've also drawn the line of the strut brace and the floor of the battery-area, and now i'm going to measure that distance up and see what sort of sub I can squeeze in there based on it's magnet size.
Then hole-cutting and carpeting. *phew* And this is after a 12 hour nightshift with no sleep!
I love my skyline but I have just bought a pretty decent stereo. Whats someones thoughts on what it will sound like?
It consists of, top of the range rockford fosgate head unit, 2nd from the best kicker splits in the front, top of the range pioneer 6x9's (the yellow kevlar ones) and a jbl amp which is 110watts rms per channel. Is this a good match up? looking forwared to driving down to sydney with this cranked
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
