Hi all,
Im looking at the HKS T04Z and the 3 exhaust housing sizes available and deciding which will be the most suitable for my built RB26.
My question is, with my car being predominantly a street car with occasional drag and circuit work, which housing size will be most suitable?
According to the HKS catalouge they are available with a .61, .81 and 1.00 housing, and so far the common opinion seems to be that the .81 is the go.
I realise the garrett and HKS equivilents are much the same, but is anyone here actually using on of the HKS versions?
Thanks
Nick
:rofl:
https://www.sau.com.au/forums/topic/101130-hks-t04z-which-exhaust-housing-size/
People who talk about them say they chose the .81 for RB26's (HKS version) . The turbine is a TO4 P trim which is very common in the turbo world , Garrett do heaps of different a/r TO4 P trim exhaust housings in T3 or T4 mounting flange pattern and single or twin entry (split pulse) . Some are saying that the spanky HKS drilled compressor cover is unnecessary because that TO4R compressor is not prone to surge .
If I was buying one I'd get the Garrett version because I cannot afford the extra ~ grand for HKS particularly since the cartridge/wheels are identical . Also I don't think these need the huge T4 mount flange pattern that HKS versions have . I have a couple of snaps of one with the TO4S .70 a/r comp cover and can't remember which Garrett exhaust housing .
Cheers A .
Thanks mate, im looking at the HKS version purely from opportunity as I can pick one up for a decent price while im in Japan in a few days.
Any idea on response that could be expected from the .81?
Response will be pretty much similar to the Garrett version (if not identical)... theres a few threads in forced induction, I think someone made 600 odd hp at the rears and on full boost before 5000rpm.
I know someone who grabbed a Garrett one with the .61 rear housing on a standard capacity RB26. On 25ish psi it made 370kw at the rear wheels and is on full boost before 4000rpm, but it runs out of puff top end (possibly too small turbo).
Seems the .81 housing is the best all rounder, providing power to redline and fairly responsive.
my personal option would be as follows....street RB26...0.61, street/circuit RB26...0.61, street/drag RB26 0.81, street RB27/28 (ie. stroker) 0.81, street/circuit RB27/28 0.81, street/drag RB27/28 1.00, street/circuit RB30...0.81, drag RB30 1.00.
this is only my personal opinion.
hope this helps mate
Paul
Edited by DiRTgarage
Paul, I would lean towards street/drag if anything, and I would prefer to go for the .81 than buy the .61 and find it falls short
If leaning towards street/drag then the 0.81 would be my choice with std capacity and crank...as per my guide.
good luck with your purchase...(bastard!!)
certainly seems like the .81 is preferrable, im running GT-SS's now and its because of their top end 'lack of puff' that im entertaining the idea of a single conversion :blink:
Simple answer = 2 X 2530
:D cheers :)
:wub: cheers :D
or Garret gt2560r x 2 (pretty similar results)
i still am amazed none has tried to find out what the IHI turbos are on the Z-Tune personally i think the turbos nissan pick for there ultimate gtr after 15 year of development might be pretty damn good.
pete
ps if i wanted nasty street/drag twin gt2835 hks kit or twin gt3071r
:wub: cheers :D
but that was not the question....
you are correct though...a street/drag/circuit GTR is great with 2x HKS 2530's
its the best all round turbo for the RB26...
this is only my opinion...
    • LS is a good motor, but it hurts my soul when I see it in a RB. Guess it fixes the oiling issues lol.
    • I'm confused. Does this qualify as "Gregging" or are you somehow avoiding the Gregging?
    • More assembly going on, with all sorts of "bolt right on bro" scenarios going on here. Smartly, PTV clearance was checked. And I say smartly because it turns out that the intake was 0.009" from piston meeting valve. This is 0.23mm. This is very not okay. A fast meeting was facilitated between engine builder in Australia and engine builder in the USA which was actually incredibly helpful and constructive actually, various ideas thrown around to get around this issue including: 1) Retard the cam timing which would have brought the exhaust valve closer to meeting piston (it was 0.065") which was uncomfortably close to begin with, and change the cam profile making it 'laggier' 2) Much larger head gaskets which would reduce compression, but half the point of this was to increase compression. 3) New set of pistons ($$$$$$$$$$$$$$$$$) 4) All of the above 5) Get ghetto The concept is you get sticky sandpaper and stick it back to a valve, slightly larger than the valve you/I'm using, like say from a LS3/rectangle port head. You now have a very super advanced flycutting tool to modify your pistons in your block. Then you install it in your head, and attach the other end of the head to a drill. Then you just replicate your valve smashing into a piston with your spinning drill.   This is the result. Repeat many times. It is strongly recommended you have some kind of fixed stop when doing this for extremely obvious reasons because if you press too hard then you're well into apocalyptic repercussion land. The minimum clearance on the intake valve is now 0.075" this is still in the "Too close to be really comfortable" and into "It should be fine" land. Supposedly in the real world the clearances will be slightly bigger. Guess this is what happens when people push envelopes for N/A engines instead of adding boost! Time to move onto the new, upgraded, higher ratio roller rockers from Yellaterra, all tapped and threaded with a stronger bolt for better stability. Very nice. Lets see how they fit. For f**ks sake. Time to bring the grinder out for these aftermarket, machined and CNC'd heads. Looks like the new, beefier rocker from YellaTerra has gone from Bolt on part to "Bolt on part". Well, lets see how this bolt on crank scraper and windage tray goes then, shall we? There actually is more clearance than they specify for this thing, but seeing it all move as you check it is terrifying when you see it all so very very very very nearly hit things. But after all, this is what the item is designed to do after all and actually did bolt on perfectly and have enough clearance to everything and some very clear and direct instructions. So +1 to Improved Racing I suppose. As above with the windage tray on. Photo of breaker bar wonkiness for added lols. Next up: Oil pump/front cover/water pump/sump and then it's time to actually install the heads, pushrods, head bolts, valve cover gaskets and such is all there and ready to go. (except the oil pump bolts which were previously longer for more clearance with the previously perfectly installed double row timing chain). There's definitely a sense that someone other than us has been here before and done everything perfectly, or at least considered it and came up with working solutions. Perhaps the previous cam was 6deg advanced to avoid PTV issues with the milled stock heads? In any case when I attempt to sell this stuff the buyers are going to be very directly informed.
    • my catch can is pretty easy to empty but it overflows due to the blowby/crank case pressure etc. max I have drained is ~600ml even with a ~2.3L capacity. So it is not just about having to drain it out its the mess it makes down the firewall and under the car and rear passenger tyre from the overflow oil being blasted by screamer + air in general. Ending up on the ground cleaning the oil up and having oil on your arms when everyone else can chill and watch the other sessions gets old fast
    • Yeah - the secret learned a long time ago is that the RB likes to belch oil out the covers, and/or starve the pump because it drowns the head in oil, because the upflow of crankcase gases from piston blowby comes up through the oil drain holes in the block and prevents the oil from flowing back down. The external vents from sump are about creating an alternative path/much more XS area for gas flow to decrease the gas velocity up through the oil drains and allow the oil to get back down. So, it's not about pressure at all. It is about flows - gas up and oil down - or when it's not working, gas up and oil not going where it is supposed to after it arrives at the top, except out through the cam cover vents. And regardless of whether the catch can is vented to air or vented to the turbo inlet, it must still be vented because a sealed system would blow out the crank seals, or something equally bad.
