Hi all,
Im looking at the HKS T04Z and the 3 exhaust housing sizes available and deciding which will be the most suitable for my built RB26.
My question is, with my car being predominantly a street car with occasional drag and circuit work, which housing size will be most suitable?
According to the HKS catalouge they are available with a .61, .81 and 1.00 housing, and so far the common opinion seems to be that the .81 is the go.
I realise the garrett and HKS equivilents are much the same, but is anyone here actually using on of the HKS versions?
Thanks
Nick
:rofl:
https://www.sau.com.au/forums/topic/101130-hks-t04z-which-exhaust-housing-size/
People who talk about them say they chose the .81 for RB26's (HKS version) . The turbine is a TO4 P trim which is very common in the turbo world , Garrett do heaps of different a/r TO4 P trim exhaust housings in T3 or T4 mounting flange pattern and single or twin entry (split pulse) . Some are saying that the spanky HKS drilled compressor cover is unnecessary because that TO4R compressor is not prone to surge .
If I was buying one I'd get the Garrett version because I cannot afford the extra ~ grand for HKS particularly since the cartridge/wheels are identical . Also I don't think these need the huge T4 mount flange pattern that HKS versions have . I have a couple of snaps of one with the TO4S .70 a/r comp cover and can't remember which Garrett exhaust housing .
Cheers A .
Thanks mate, im looking at the HKS version purely from opportunity as I can pick one up for a decent price while im in Japan in a few days.
Any idea on response that could be expected from the .81?
Response will be pretty much similar to the Garrett version (if not identical)... theres a few threads in forced induction, I think someone made 600 odd hp at the rears and on full boost before 5000rpm.
I know someone who grabbed a Garrett one with the .61 rear housing on a standard capacity RB26. On 25ish psi it made 370kw at the rear wheels and is on full boost before 4000rpm, but it runs out of puff top end (possibly too small turbo).
Seems the .81 housing is the best all rounder, providing power to redline and fairly responsive.
my personal option would be as follows....street RB26...0.61, street/circuit RB26...0.61, street/drag RB26 0.81, street RB27/28 (ie. stroker) 0.81, street/circuit RB27/28 0.81, street/drag RB27/28 1.00, street/circuit RB30...0.81, drag RB30 1.00.
this is only my personal opinion.
hope this helps mate
Paul
Edited by DiRTgarage
Paul, I would lean towards street/drag if anything, and I would prefer to go for the .81 than buy the .61 and find it falls short
If leaning towards street/drag then the 0.81 would be my choice with std capacity and crank...as per my guide.
good luck with your purchase...(bastard!!)
certainly seems like the .81 is preferrable, im running GT-SS's now and its because of their top end 'lack of puff' that im entertaining the idea of a single conversion :blink:
Simple answer = 2 X 2530
:D cheers :)
:wub: cheers :D
or Garret gt2560r x 2 (pretty similar results)
i still am amazed none has tried to find out what the IHI turbos are on the Z-Tune personally i think the turbos nissan pick for there ultimate gtr after 15 year of development might be pretty damn good.
pete
ps if i wanted nasty street/drag twin gt2835 hks kit or twin gt3071r
:wub: cheers :D
but that was not the question....
you are correct though...a street/drag/circuit GTR is great with 2x HKS 2530's
its the best all round turbo for the RB26...
this is only my opinion...
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
