Well, let me be the first to admit that I am still learning to drive my car, so with that in mind...
Who wants to go to MC with me, do da, do da?
With any luck Master Kenneth will be one of the instructors & we have all seen him in action. The drags are great, but how many straight roads do we go on?
Hands up people:)
Cheers,
Mike.
https://www.sau.com.au/forums/topic/10114-mc-motorsport-who-wants-to-go/
  • Replies 81
the normal MC day is just short course work, dodging people, err cones and finding out what your car is capable of i guess. it's instructor lead, no wet roads (unless it's raining :D) and lots of fun. i'm taking this for granted as i've never been and only spoken to the guy who runs it on the phone. others here have been and gtr ken instructs.
i'm going this sunday.
there are advanced lesons, but you have to book and wait.
Originally posted by Pva_Glue
if it's rainging I am there.. :D
if not I am happy to just watch
cheers
Joe
If it's rainging - wtf is that:lol: Don't they put dogs down when they get this way:lol:
Sorry Joe - I could follow you around the forums for hours correcting your Jinglish - I must be bored & now I am post whoring...ooh aah:shake:
Am interested in this as well - is it mainly about performance driving?
A guy at work also told me about MB Motorsport (not a typo) who were offering deals for advanced driving courses as well. They do a city one (80 kmh) and a country one (110kmh) so it seems more everyday driving skills compared to racing or performance driving.
Have only looked at there website - MB Motorsport
I haven't done either so no views on either of them
pwptf
Have emailed John Clark re getting a group in the MC days
Cos the team numbers are down there is a possibility you could run and they would just put whoever has entered into teams.
Don't have to commit to the series which is what is putting people off.
Would need CAMS Level 2S $91 which would allow you to do MC , MaxAction, Enjo Speed Event Series.
You would also have to join a CAMS associated car club.
If we have any interested people at that , I will pursue it a bit harder with John.
Cheers
( get into the twistys )
Ken
Yeah, I'm interested in that, it will cost a bit a first to get involved but them I'm sorted for a year. Where can I get a list of CAMS affiliated clubs, and are there any you recommend.
When does the MC series start?
See'ya:burnout:
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
