It would be good to get together a list of CAMS license holders in the club so we can:
* Find replacement drivers when necessary
* Organise practice days
* Get together ppl for hillclimbs etc.
So, post here if you hold a CAMS license!
C2NS - motorcross, khanacross
C2S - hillclimbs, supersprints
C3 - curcuit racing provisional
C4 - curcuit racing national
C5 - curcuit racing international
Also post if you've done an approved course but haven't got around to the paperwork yet.....
Mods, can you make this thread sticky?
https://www.sau.com.au/forums/topic/10115-cams-license-holders/
  • Replies 188
Posted Images
  • 1 month later...
hey all, i've got a C5A
international.... expensive
It would be good to get all the guys from the club out to do some big track days....
Mr Miagi.. do u drive a 32 GTR in combined tourers?
i saw you at EC couple of weeks ago racing Barry Sternbeck... until you blew a turbo.. shame, you were doing so well.
later guys
  • 4 weeks later...
Well, I've just upgraded to C4, no more P plates for me!
Maybe the cops will leave me alone at last :D
Now I've just gotta get my hands on one of those C5 licenses like S4PLAY before 22nd November
  • 1 month later...
Well, good news this weekend.
Skylines Australia NSW is now CAMS affiliated, so we can issue L2S (sprint) licenses directly
Details here:
http://www.skylinesaustralia.com/forums/sh...5725#post355725
    • Google says for a 1998 Nissan Maxima to pull/pry, and the metal pin might even come out with it. I'd do a bit more googling, there was a few videos, find some where the shafts/needles appear most similar and compare the techniques.
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
