hay guys just asking is it hard to get a cams licence what do you have to do to get one is it very expensive and what does it allow you to do
getting a cams license is easy, depending on what you want to do.
I recently applied for a L2S License [meaning Level 2 Speed] which allows you to partake in most events like hill climb, super sprint, motorkana, etc. The L2S License costs $85 and you can may by money order, cheque or credit card.
you have to be part of a CAMS affiliated Club in order to get a cams license also. The SAU NSW Members club is the club to join for all you SAU people.
You also need to meet certain scruitneering criteria, like having a fire extinguisher in the car etc. [ i wont go into much detail]
you will also need a number and triangle for your car you can get magnetic ones, much like i purchased from the NSCC.
its a pain in the ass setting everything up and getting everything organised, but it is the best fun when your out there racing!
hope this little info helps you a bit
-mark
[ps ive got a L2S License]
  • Replies 188
Posted Images
Unless you want to be cool in which case you join the SAU Vic for all your CAMS needs!!! I mean we even have a track sprint club championship!
:chairshot
:rofl:
  • 1 month later...
I would like to go on the licence list , I hold a current C4!
It would be good to get together a list of CAMS license holders in the club so we can:
* Find replacement drivers when necessary
* Organise practice days
* Get together ppl for hillclimbs etc.
So, post here if you hold a CAMS license!
C2NS - motorcross, khanacross
C2S - hillclimbs, supersprints
C3 - curcuit racing provisional
C4 - curcuit racing national
C5 - curcuit racing international
Also post if you've done an approved course but haven't got around to the paperwork yet.....
Mods, can you make this thread sticky?
  • 1 month later...
I hold a L2S, and have competed in a couple of GP Rallys and a heap of sprints over the years. Currently getting the car log-booked so I can enter the Victorian Hillclimb State Championship next year. I also hold a CAMS Scrutineers licence (level 3) and a Communications licence (level 4).
  • 2 months later...
  • 1 month later...
how do i get cams licence
Go to http://www.cams.com.au/content.asp?PageID=...tors&ObjectID=2 and get the appropriate application form. Depending on the type / level of licence you require, you may need to do some Observed Licence Tests (OLTs).
Don't forget that you will need to be a member of a CAMS-affiliated club first...
  • 2 months later...
cool sanger....which meets do you race at? the same historics as the group A cars, or the GEAR meets?
Hey duncan,
I race at the hsrca meets, It was good to see the skylines out at them. I have been spectating at the events for about 4 or 5 years but havent ever seen them before. I gues they havent been eligable till recently??????
If you get the gtr ready for racing again this year i will have to try and come and do some flag marshaling so that i can apply for my full licence next year.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
