My central locking thing has stopped unlocking via my remote. For some reason its locking as usual, but the unlocking part is not working and i'm having to resort to what's called a door key (erk)Its a Hornet alarm/immoboliser unit. Was all working fine until about a week ago.
Is there a separate motor thing that unlocks as opposed to locking that could be dud'ded? Could it be a simple thing such as blown fuse?
I really should just pull the door apart, but just thought I'd ask before I did, 'cause that will probably be a right pain in the butt.
https://www.sau.com.au/forums/topic/10117-central-locking-probs/
There is only one door lock actuator. Unlocking is achieved by simply reversing the polarity of the power going into motor as compared to locking. Therefore, the fact that you can still lock means the motor is ok. Your problem is either with the alarm, ie. no unlock signal going into the central locking controller, or one of the relays in the central locking controller itself. You should also check that all the wirings are ok.
Unfortunately, I don't know where the factory central locking controller is (near passenger side kick panel maybe?), as I put in an additional controller (2 relays) when I installed my driver side door lock actuator along with the alarm. Someone here must know. Since your alarm module is in the engine bay, maybe the heat has something to do with it. Check for dry solder joints. Good luck.
I think you will find that the actuator from the alarm has come loose on the existing door-lock.
The solenoid piggybacks the central locking, and is held in place by a grub screw. The screw loosens and allows the alarm solenoid to slide independent of the central locking.
Pull the door panel off, reposition the solenoid connection and tighten the grub screw. All fixed ;-)
That could quite be it... Just before it stopped working, it was unlocking, but wasn't unlatching the door fully, so i had to pull it open over the catch which I knew wasn't a good thing. So that could well explain it coming lose. A day or two after that it stopped working.
Thanks elk and henros, I'll let you know how I go in the next day or two when I get the door apart.
my car did that just recently, but it fully seized, and i had to "break" into it and pull the door apart, in the end there were two bits of metal in the locking part that were rubbing and they werent supposed to so i took a spring out and fixed it dodgy style, but it works good
Operation complete success!
Turned out the locking actuator (what is really just a motor which pushes or pulls a rod which locks or unlocks the catch) had slide back like you said blind_elk. Therefore it wasn't pushing forward enough to unlock.
There are a few screws that allow it to slide back and foward to adjust, and obvious during heat, moving, whatever they slid back. So slid the thing back forward again 'till it was doing what it was supposed to do, tightened all the screws again, and bamo, all working again.
Thanx for your help - no more key again..yay
While I'm here.. for everybody else, how to remove door trim on R33:
1. Open door (dur) and wind window down.
2. Remove screws at bottom of door trim
3. Remove lug at bottom of door handle pull pocket via flat head (on the elec window switches panel).
4. Remove the screw and gently clip out the whole elec window switches panel.
5. Remove the plug to the switches panel
6. Unclip plastic face behind inside handle (where the pull out thing is)...you might need a flat head to lever off There is a screw behind which needs to come off
7. Gently at sides of door trim, lever off edges each side.
8. Pull door trim at bottom up over everything and out
9. Fiddle inside the door to your hearts content.
10. Install new speakers in front door while you're there (standard ones 15W max :lol:
Putting back on is reverse of above.. Although some of the plastic plugs used to secure the trim to the door might have to be pulled out and need to be sat back in the trim before you stick the trim back on (you'll see what i'm talking about once the door is apart).
Its probably easier than it sounds above! Much easier to do than my old cars thats for sure.
    • I havent bought a manual cover for the dash yet and no cluster change, won't bother me too much, I just need to get that auto box gone, manual in! I miss my manual. 🤪. We started last weekend and managed to get the box out. Planning to start putting it in this weekend and then order a single piece tail. We were super careful to take time and not damage anything. It's my first time working under the car.  With my S15 mainly worked in the bay. This time, it was a headache because of three or four bolts only. They simply didnt want to leave thei homr and the one securing the tailshaft, another above the GB, and the one securing the lipstick was a shit. Mates mate, Davo caught fire 🤣, nearly opened his chest up with a grinder 🤦🏽‍♂️ and both mates nearly had a plate from the box land and slit their head open. Fun times. We all survived. Not the easiest working with limited access on jackstands. As I'm sure we can agree these are the memories which make us love our car. For all three of us, was an awesome weekend and Sunday 3.30am before tools down was a fantastic effort. I need to upload pics, but looks like it needs to be via Url now. We used to be able to just upload pics back in the day. It's been that long! 🤪 Im currently spraying rustoleum under body, not because it's rusted. It's super clean, but just so it's protected for the next 10 years. There was a few surface rust spots. Which pretty much wiped off with a 3M scourer.  Really impressed with how well the previous owner maintained it. Bank account went down so quick! Service, then GB - managed to get a spanking new 34 genuine box from Nissan. All the rest of the conversion parts from Kudos.  Went with a Nismo short shifter. New pedals and Exedy Clutch and FW. Ordered the Prp Rear Main Retainer kit which should arrive Friday and my first engine mod part just like I did with my S15 will be the Tomei Expreme Turbo Outlet. Already on order. It'll likely sleep next to me on a pillow during the coming months. 🥰 Last build was on my JET200GT profile and on SAU and Hardtuned I had documented the build. Planning to try to do that again. Brands feel scarce now. Wish we still had ARC and Apexi parts readily available. Exhaust - need some advice on this. I had an Apexi exhaust on the S15 and loved the tone. My mate had a HKS HP Silent on his 33 and suggested I go with that to avoid drone. I can't remember hearing an RB25DET running that so will likely need to wait for a meet or something to hear it.  Not after big power, just enjoy building it, and drivability with minimal negative attention.
    • Have a chat with Ben at Moore Performance or Jesse at JS Performance.
    • Thanks both. All good advice. Reminds me of drilling through stone wall for drainage pipe 😬 I'll let you know how I get on if I still have use of my hands afterwards 😅
    • Finally got shipping number for the intake and throttle body, shipped by UPS, so "should" be in my hands sometime next week, fingers fracking crossed
    • I'm so far behind in the jobs I have to do at both work and home (including car) that I have become immortal. There's simply no way that I can die now.
