you should look into the following:
a good cold air intake
ecu that supports afm with 02 feedback
larger fuel pump
larger injectors
nismo fuel pressure regulator
what tyres?
what clutch?
3.5" split dump at a minimum
what power to you plan to make?
read the thread the mafia has done as it should cover most of the questions you will have regarding it. it certainly wont be cheap and it will be laggy
https://www.sau.com.au/forums/topic/101184-gt30/#findComment-1848157
As it stands now, you will have a lag monster of a turbo with no top end power. Basically any turbo upgrade requires a fuel upgrade (ecu and fpr at least) so not only will your car run like crap, but you'll also have less power than stock because your computer won't be able to run the turbo.
You're far better off waiting until you have the money for an ECU and tune ($1.5-2k) before you bolt that turbo on.
https://www.sau.com.au/forums/topic/101184-gt30/#findComment-1848331
    • If I get a larger battery and it hangs off the edge of the frame rail, would this be an issue? With FMIC a lot of people downgrade their battery size due to less room for shit, was wondering if it would affect anything but it would still be tight via the clamp.
    • Yeah, the E34 touring is like hens teeth.  This one is really nice, she's a touch rough but we'll get there. Horrible, broken key buttons were irritating me so I bought some replacement buttons and new batteries. The pic makes them look gross still but it is such a difference. I accidentally broke a little bit of the new button on one of them by using a pick to get it in place. Super good service by the guys at Remote Pro who offer free shipping regardless of order. Hats off to them.
    • My R32 is about 1300kg. There's your 500kg right there. I've stated before that I hate all modern cars. The fact that something the size of a Corolla is typically 1.5 ton these days is sickening. Should be 900kg like in the old days. What the f**k are modern materials for?
    • Ah right that makes sense.
    • Stock R33 except for suspension, tyres, brakes, and seats is a great ride. Get that power up around the 200mark, and it's great and reliable.
