Hey guys,
Well I've recently purchased an RB26 engine out of an R34 and it is on its way here now from Japan.
Was just wondering what's involved in getting it fitted in an R32?
I've heard that its a pretty straight forward job, but was just wondering if everything is interchangeable, or would i need to have certain things changed (such as the ECU, various hoses etc)
Just wanna organise things well in advance, so that there are no surprise set backs when the engine gets here.
Also, while I've created a thread, how would it effect overall performance? I'm assuming it could only be beneficial towards power output...
Thanks,
Ali.
Edited by IOWNU
https://www.sau.com.au/forums/topic/101187-fitting-an-r34-rb26-in-an-r32-gtr/
it would be easy if you have the 34 GTR cooler as they have the inlet temp sensor mounted in the cooler outlet. if not you can always drill and tap a hole in the plenum and mount it there. other than that i can't forsee many dramas. i would use the R32/R33 GTR ecu too.
What ECU/wiring loom are you intending to use? There are a few drama's that Richard has missed:
CAS: R34 use a different design crank angle sensor, you either need to change the camshafts or splice the new CAS wiring into the R32/33 loom
EGT: R34's also run an EGT sensor, not an issue to weld or block off the hole with a bolt. It's in the rear dump pipe near the flange.
Easiest solution would be to run the R32 loom, as the R33 and R34 looms have additional connectors which may not be compatible with your car i.e. ABS, left side indicator, alternator. But you will still have the issue of CAS, and the mounting tabs on the fuel rail for the lower loom (knock, oil temp/pressure, AAC) will not match up, so reuse your R32 fuel rail. Also use your R32 AFMs - is it a stock computer currently in your car? Tune will be a touch out regardless.
If you have both engines out side by side it would be pretty easy to configure the R34 engine for use in the R32, and just swap out the model specific parts.
Edit: Also forgot the ignition system on an R34 is direct, so you either re-use the R32 ignitor pack/loom/coils or use the entire R34 loom/cpu/etc.
Edit again: Also need to change the sump/front diff assembly to R32/33 as the 34's use a 3.45:1 vs 4.11:1 in the older models.
Hey thanks for the very informative post!
Looks like theres more work to be done than I anticipated! :P
hey iownu
iam planing the do the same thing as you with my r32 gts4.
and wondering how much did you pay for the engine???
thanks
Hey mate,
Here's the thread about how much the engine cost me, importing it etc.
http://www.skylinesaustralia.com/forums/in...showtopic=99723
hehe, trust me to pick the lamest part of the whole thing. lol listen to doughboy.
lol.
Thanks for your info about the cooler as well.
Just feels like there are so many small things that need to be done. :P
you will certainly need to keep your wits about you if you are doing it yourself.
Nah def. won't be doing it myself.
I'll leave it to the mechanic. But i can anticipate him calling me up everday telling me that he needs another few days etc, for this and that.
See how it goes.....
  • 2 years later...
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
