Hey guys,
Well I've recently purchased an RB26 engine out of an R34 and it is on its way here now from Japan.
Was just wondering what's involved in getting it fitted in an R32?
I've heard that its a pretty straight forward job, but was just wondering if everything is interchangeable, or would i need to have certain things changed (such as the ECU, various hoses etc)
Just wanna organise things well in advance, so that there are no surprise set backs when the engine gets here.
Also, while I've created a thread, how would it effect overall performance? I'm assuming it could only be beneficial towards power output...
Thanks,
Ali.
Edited by IOWNU
https://www.sau.com.au/forums/topic/101187-fitting-an-r34-rb26-in-an-r32-gtr/
it would be easy if you have the 34 GTR cooler as they have the inlet temp sensor mounted in the cooler outlet. if not you can always drill and tap a hole in the plenum and mount it there. other than that i can't forsee many dramas. i would use the R32/R33 GTR ecu too.
What ECU/wiring loom are you intending to use? There are a few drama's that Richard has missed:
CAS: R34 use a different design crank angle sensor, you either need to change the camshafts or splice the new CAS wiring into the R32/33 loom
EGT: R34's also run an EGT sensor, not an issue to weld or block off the hole with a bolt. It's in the rear dump pipe near the flange.
Easiest solution would be to run the R32 loom, as the R33 and R34 looms have additional connectors which may not be compatible with your car i.e. ABS, left side indicator, alternator. But you will still have the issue of CAS, and the mounting tabs on the fuel rail for the lower loom (knock, oil temp/pressure, AAC) will not match up, so reuse your R32 fuel rail. Also use your R32 AFMs - is it a stock computer currently in your car? Tune will be a touch out regardless.
If you have both engines out side by side it would be pretty easy to configure the R34 engine for use in the R32, and just swap out the model specific parts.
Edit: Also forgot the ignition system on an R34 is direct, so you either re-use the R32 ignitor pack/loom/coils or use the entire R34 loom/cpu/etc.
Edit again: Also need to change the sump/front diff assembly to R32/33 as the 34's use a 3.45:1 vs 4.11:1 in the older models.
Hey thanks for the very informative post!
Looks like theres more work to be done than I anticipated! :P
hey iownu
iam planing the do the same thing as you with my r32 gts4.
and wondering how much did you pay for the engine???
thanks
Hey mate,
Here's the thread about how much the engine cost me, importing it etc.
http://www.skylinesaustralia.com/forums/in...showtopic=99723
hehe, trust me to pick the lamest part of the whole thing. lol listen to doughboy.
lol.
Thanks for your info about the cooler as well.
Just feels like there are so many small things that need to be done. :P
you will certainly need to keep your wits about you if you are doing it yourself.
Nah def. won't be doing it myself.
I'll leave it to the mechanic. But i can anticipate him calling me up everday telling me that he needs another few days etc, for this and that.
See how it goes.....
  • 2 years later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
