R33 Skyline Gts-t 1994 Manual
Located on the Sunshine Coast
Very Good Condition - 95000kms
Interior very clean
Wine Red
6 months rego
$14800
PM me or call 0412 411 919
Extras:
Clarion Cd player / Front Speakers
Active LSD model
HKS 2530 Turbo (10,000kms old)
Low King Springs
Apexi Front Mount Intercooler
new front brakes + fluid
K&N Panel Filter
3" Dump pipe and full exhaust (new 3" cat)
Ceramic Heavy Duty Clutch (10,000kms old)
18" Wheels, Tyres Good Condition
New front camber/castor kits
A/C not working - needs re-gas, compressor ok.
Edited by ben333
https://www.sau.com.au/forums/topic/101197-1994-r33-gts-t-manual/
  • 1 month later...
  • 3 weeks later...
    • I hope one day I can do it like you. Your engine looks great.
    • If there's nothing else I can do I'll probably do something like that Someone on the internet said that ca20s and ca18 engine blocks are the same and that you can use a ca20 engine block and put ca18det parts to make a ca20det Do you think this is possible or will it damage the engine?
    • Yeah, I did some research and found out that some things are different.
    • Makes sense, thanks! Consider me very impressed. And I very much appreciate the effort in documentating all of it. You'd be surprised, or maybe not, how many people this reaches who search for things online. Anyways, I shall continue to read all of it, understand maybe a quarter, and hope that some of it sticks if I ever end up in a situation where it's relevant
    • 'Did' work on them is more accurate ~ on the R31 Skyline forum, you can spot me as 'Solder'... I've written quite a bit about the 4R01 boxes there, and I ended up reverse-engineering the older TCU type operations, so we could fudge a custom TCU to pull off other tricks...and like all things, when you do it a lot, see the failure patterns, have to find parts etc etc, your head ends up filled with whys and wherefores... there was a reason Nissan went with these in more than 60models over 16+ years... all in all, the JR401E based design is an interesting study, as Nissan changed things over the years in a never ending battle against them lunching on themselves <grin>...by the time the RE4R01A rev.C came out (often referred to as RE4R01B), they'd more or less perfected the design...
