Hi guys, as my car is not a daily driver I would like to remove my air conditioner condenser and all associated air con piping from my R32 GTS-4 in favour of further weight reduction.
Could anyone give me any instructions/tips/considerations on doing so?
Cheers :P
Edited by Remix-
one thing i noticed that made the whole thing easier on my gts-t was a knife. It's just an air conditioning unit and i could care less about selling it for a few bucks. so I took a bolt cutter and sharp serrated knife to everything and unbolted/removed small pieces instead of keeping it all together.
for the amount of sanity that would have been lost due to pissing about with neatly doing things, the money wouldn't have been worth it.
if you don't care about not making a couple dollars off the selling of your used system, i highly suggest this route :P
i suggest using a mallet on your head....
Anyhow, you will need to pull off the piping and things, that is fairly easily. You will also need to move the power steering pump and remove the power steering belt to make it easier to get to the correct bolts. So you will have to undo it and push it to the side to allow you to the bolts that get the compressor off. I didn't find it too difficult, never having done it before.
Its probably an hour or so job to get it out, but the thing does weigh a fair bit, if thats your thing.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
